G50/52 in a 993
hello
I have a 95 993 that i have done a turbo conversion to. Id like to fit a g50/52 in it. Can someone confirm if it will bolt right up. It seems to be about an inch longer than the g50/20 6 speed that was in the car. Thanks |
gearhead
The turbos do have a longer bell housing and quill length than the normally aspirated gearboxes. 1.1" if memory serves. Whether of not there would be tunnel clearance issues on a 993 chassis not something I can tell you.
Banned
gearhead
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Banned
Shift rod is not an issue to physically fit it, It will work, shift rod is not an issue, just extend it a few mm (chassis side),or get a 965 shift rod, BTDT., Stefan.
gearhead
The question wasn't about it hitting. It was about which one was the right length, which you answered.
Banned
It asks if it will BOLT right in, been an inch longer wont hurt bolting it to the chassis, this mod is very easy to achieve, cheers, Stefan.
the trans mount bolt holes are an inch more forward than the chassis
Banned
Did your gearbox came with its mount?
Metal Guru
Is your conversion making lots of HP? Are you having any issues with your current 6 speed?
I've actually seen a 964 Turbo, making stock HP (320 at the flywheel) that used a G50 6 speed from a normally aspirated 993 with no issues. The car was tracked regularly, too. You *might* be ok with your current tranny.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
yes it came with the g50/52 mount .
it made 600 at 1bar on a break in tune |
Banned
Ok, and you have a 993 chassis correct?, that tranny will handle double that HP!, cheers, Stef.
Chain fence eating turbo
