filling my bumper holes
I finally got around to filling the bumper holes for my narrow body turbo. I used a 115v mig with a spool gun. It was really the first time I've mig alum. I had considered other methods, but this seems to be the best for a bumper that is going to get hot from the turbo. I am sure there is an epoxy that would be fine, but this was fun. The bumper needed to be painted anyway.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 02-22-2013, 06:20 PM
mark houghton's Avatar
Looks good - well, looks pretty bad actually, but nothing that a little bit of grinding and filing and a thin coat of bondo won't fix. And paint, but of course!
Wish I had a mig, tig, or even frig welder. All I have is an antique stick welder (antique, 'cause I've had it since I bought it almost 40 years ago). Give me some 6013 farm rod and I'm good to go blow holes with the best of 'em.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 02-22-2013, 09:19 PM
Brando
quattrorunner's Avatar
Wasn't aware you can weld alum with mug 115v?
Turbo powa!
1977 911s. it's cool
Old 02-22-2013, 11:56 PM
I didn't either until I came a across a very lightly used Clarke "Hot Shot" for $300, which included a spool gun. It does need to be on a circuit that doesn't run a bunch of other stuff as it will need a lot of amperage otherwise you will not get good heat penetration. So I used the fridge outlet in my garage. For what I do it will be fine until I get to a point to move to a tig. Once the heat and wire feed are set right it moves right a long and puddles the material nicely.
I found that running the argon flow rate at 18 vs. 15 helped quite a bit.
Old 02-23-2013, 06:24 AM
xbmwguy's Avatar
devil are you going for something like this?
Old 02-23-2013, 11:20 AM
Brando
Looked up clark hot shot. It doesn't use argon on the ones I saw. You would need this though?
Turbo powa!
Old 02-23-2013, 11:39 AM
Banned
Never heard of a "mug" welder before - must be some new invention used to repair facial damage?!
Old 02-23-2013, 11:50 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
JB weld works pretty good too
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 02-23-2013, 01:07 PM
Brando
Ronnie, obvoisly you've never read my posts before. I have invented many things with my spelling.
Turbo powa!
Old 02-23-2013, 01:42 PM
Banned
Ha ha! Yep, you are indeed very inventive!
Old 02-23-2013, 01:56 PM
Yes but I think I will eliminate the rubber corners as well.
Old 02-23-2013, 03:58 PM
wacko's Avatar
I am planning on doing the same repair on the bumpers of my 1978 911sc.
Are the bumpers Aluminum??? or steel?
1978 RUF 911SCR
Old 12-22-2013, 12:04 PM
They are aluminum. Use a backer plate of dissimilar metal like copper.
Old 12-22-2013, 01:26 PM
Did the same thing just the other day. I'm going to eliminate the moldings as well. I just have to come up with a trick way to mount the bumpers to the shocks.
Old 12-22-2013, 05:29 PM
beat you to it,...working on the front now
Old 12-22-2013, 06:22 PM
930T Owner
Hams930T's Avatar
It's a fun project for sure!
I recently did mine. I left the holes for the rubber strips but I never actually mounted them. I kind of prefer my bumper without them.
Before:
After (sorry don't have the exact angle shot to compare on this computer):
Chris.
Hams930T
2017 Turbo S
Old 12-23-2013, 07:46 AM
That is some heat penetration there. Spool gun! 220v?
Old 12-23-2013, 08:21 AM
Nope,
I used to have a really nice miller 30A spool gun for the mig machine. I ended up selling it since I no longer use it.
Those were done with tig.
Old 12-23-2013, 09:09 AM
Does anyone have any good tips for prepping the aluminum.
Epoxy primer before filler or filler then primer?
Old 12-23-2013, 09:12 AM
I just bought a Miller Tig for the purpose of doing alum. I hope to try it later this week. Thanks.
Old 12-23-2013, 10:27 AM
