super quick and easy question
For those of you with ac: where does the driver's side rear condenser hose come through the engine compartment to underneath the car? Is it back behind the shock or at the back corner of the engine next to the side tin and rear engine mount? Im moving forward at a snails pace replacing my hoses and ac components and i forgot where i pulled the hose through.
Thanks and a dozen karma points Aaron
84 930 07 Exige S |
Behind the shock, then follows the seam of the body down, and is secured with hose clips.
Jon |
You can see a couple of empty clamps running down the seam.
Jon |
