Banned
Radio shack diode works. But it sure sounds like you need to get the alt rebuilt.
Hey guys, I'm having an charging issue also, I'm on my 4th alternator and regulator , can someone take a pic of the diode and where it's located , thanks
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo Last edited by heliolps2; 02-05-2014 at 07:52 PM.. |
Pull out your temp/oil pressure gauge. Pull on the wire that goes to the battery light, top middle. Follow wire back to the the plastic connector. Diode is in that connector.
My other question is, can welding on the chassis mess up the alternator ?
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
![]() I got a little creative with a 3 amp ratshack diode. I haven't tried it yet but when I hooked the 2 leads together the alternator light came right on.
84 930 07 Exige S |
What makes you say that? The chared diode? My car only has 30 k miles so the brushes should be OK. Maybe a new voltage reg would be a worthwhile safety precaution?
84 930 07 Exige S |
An alt rebuild will also include going through and/or replacing your VR. Plus any quality rebuild guy will test it before tearing it apart and if it's all fine shouldn't cost you more than your time to pull the alt and make sure your don't have a fire hazard of wiring under your shroud. You still haven't said the year of your car. |
OK thanks. My car is an 84. I thought 2 and 3 where caused by the exciter diode. I'm surprised it charged at all from what I read. I'll look into having the alt tested
84 930 07 Exige S |
Tinkering Pays!!
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. |
I installed my new diode and the light operates as it is supposed to now it turns off the instant the motor fires. It also starts charging with out a throttle blip.
The only issue I see is the voltage hovers at 14.04 v. At idle. Does that seem a bit high to anybody?
84 930 07 Exige S |
Good job ,perseverance paid off!
Does it ever go above 14, like when you rev it up to 3-4 grand? I think the spec on the VR is right around 14. You don't want much higher than that or you will start ruining expensive electronics.
Just a follow up in case any body is searching the site in the future. I used diodes marked 3 amp epoxy rectifier diodes from radio shack. They are not marked with a specific type however. I got one of those cigarette lighter volt meters and it shows around 14v consistently while driving and about 13.5 if the headlights are on. I checked this against my modern commuter car and it was about the same. All signs point to positive for this 59 cent solution.
84 930 07 Exige S |
Thanks for the follow up
Tinkering Pays!!
Thanks, Shannon
I think your charge voltages are fine. Most 12v lead acid batteries charge at around 13.8. Stone cold and fully charged, a 'full' battery should read around 12.8.
Just for reference, when my regulator gave up the ghost, it was charging at around 17v and my tip-off was the smell of hydrogen sulfide gas as the battery boiled away. Didn't hurt any of my electronics, but did cause my AFR meter to read way low...as in really rich. It was the AFR that first weirded me out, then the smell, then I hooked up a volt meter to see what was going on. It happened only after shutting the car down fully warm and letting her sit for a few minutes. My guess is that it then heat soaked the regulator and cause the over charging to surface.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
84 930 07 Exige S |
Thanks mark I figured the voltage would be erratic and higher if the vr was gone
84 930 07 Exige S |
83 911 Production Cab #10
Pretty well the same story as Mark.
Happen during a Porsche coffee run and since I was following someone with a brand new muffler, I dismiss the smell as that. Bolled the battery, but no harm to the electronic. The VR would be good for 5 minutes than put out 17 Volt as soon as it got warm. Changing a VR in a Cab is a real PITA. Its a good reason to either installed a permanent voltmeter or a plug in the cigarette socket type
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
