Brando
quattrorunner's Avatar
wur 3.0-3.3 compatability
I just got me a blrur and my 3.0 wur has two vacuum ports. One on the side like the 3.3 wur and one on top that is a dummy port on the 3.3. If I just install the blwur and plug the hose that went to the top bung, will it be fine? I guess it will but never thought of this till it came up in my install.
Turbo powa!
1977 911s. it's cool
Old 02-24-2014, 01:35 PM
mark houghton's Avatar
Isn't that top port just for venting to atmospheric pressure, so the interal diaphram will function correctly? Where does that hose lead to, if you were to just plug it?
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 02-24-2014, 01:51 PM
Brando
Yeah, back side of throttle body.
Old 02-24-2014, 01:55 PM
That vent has to be open.
You can get pre molded little hoses that angle to the side or down. Or you can put a regular vacuum or fuel line on it and leave the end angled down so water doesn't get in when it rains or the car is washed.
Old 02-24-2014, 02:01 PM
Brando
Thanks.
Let me know your thoughts in these symptoms in seeing?
I have high afr on cruise, and normal afr at idle, or vise versa. Normalish afr cruise and rich afr idle(11.3.1)
I always get safe boost afr's.
My thoughts are that my single fuel pump (044) isn't providing the right pressures?
My new blwur is acting exactly the same. No real change. I know I can adjust it, but is there something inherently wrong I'm missing?
Old 02-24-2014, 02:13 PM
