Waste Gate Dump Pipe Routing
So I installed a dump pipe that I purchased from a fellow Pelicanite. My question is being that I am running stock exhaust I was only able to install it with outlet facing horizontal not downwards see below. Is that okay or do I need it to face down towards the ground? Thanks in advance with any info,
http://forums.pelicanparts.com/uploa...1396956593.jpg http://forums.pelicanparts.com/uploa...1396956628.jpg |
Some hot exhaust is aiming at your quarter panel.
For a street car that is fine as you are not on boost for long periods. I've run mine that way with no issues.
I don't know... you'll be surprised of how much heat and a little blue flame (that you hardly see), that comes out of it quite a lot... |
You could get a pair of pliers and bend the top just slightly so theres less chance of a bird flying there, or water? Or cut the ends a bit (like a flute) and depending on boost youll get diffeent sounding notes, i slit mine to play a B Minor because i like the star wars theme song and B Minor is the first note :)
Sorry if im not much help its seven in the morning here and this is the first post i read today :) |
| All times are GMT -8. The time now is 10:57 AM. |
