Your assessment is correct regarding the internals of the 930 trans.... and based on your comments, and from what I can see of the Ruf trans, the big difference remains the tail cover, and as you described, the lengthened output shaft, placement of/additional gears, and a few other details. Yes, a nice stop-gap for the time and probably still a viable retro-fit/option at present with a properly priced/reverse engineered kit. While the G50 is a nice upgrade, the level of work, cost, etc.. required for an install is not for everyone. Based on the items described above, if this were available in kit form to the 930 owner, it would be little more than a thorough trans rebuild. Quote:
80's. |
I did a G50/01 upgrade last year.
Shortened the bell housing, so That I could use my torsion bars. Modified the transmission mount so a did not have to weld new mount to the chassis. Can switch back to 930 transmission any time if I want to. A great upgrade over the 930 transmission. |
Just found a great deal on an old stock 8:41. Will let you know how it goes after I find an LSD and install them both.
Andial told me that they did not sell the 8:41s, because they are noisy. A search on Rennlist and Pelican might lead you to think the same. BTW, ignore what I said on Rennlist about SC-spec cams. I now think that they are wrong for a Turbo for the street. I will be restoring the original 930 cams in my car. |
^ I've heard similar. Figured it was worth a shot. Matt Monson at one point told me that a noisy ring gear can be managed somewhat with meticulous setup and friction coating. That was a generic statement so unsure if it applies to this this of RnP.
Albins make a taller (10:31) R&P for the G50 - CMS carry it; I considered it.. It was $3000 US at the time, Factory G50 gearsets are $900 per gear (1st involves re-welding the shaft as well).
Last I looked, core, non-broken G50/50's were reputed to be $10K - if you could find one. Good luck with that, they didn't make many, and most are either in the original car or already in an Ultima or GT40 rep... I think you have to figure a used transmission with any mileage as "suitable for rebuild", especially for high-power applications. The G50/01 with 100K I used ate about $3000 worth of factory wear parts (bearings, bushes, seals, synchros etc) before it got anything trick - and it came out of a great-driving car (shop I bought the box from had been looking after it for 10 years) that got hit in traffic. After the tall 5th I had in the 915, stock 911 G50 5th was also WAAAY too buzzy on the freeway. |
Resurrecting this thread, as there is a Ruf 5-speed up in the "911 Used Parts" forum: http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1067548-genuine-ruf-5-speed-btr-box.html
I noticed that the Ruf 5-speed has a short bell housing, like on the early 3.0 Turbos, which would shorten the wheelbase of the car, wouldn't it? I presume that was so the longer "nose" of the transaxle (where Ruf stuck the extra 1st gear) would still sit at the proper location to attach to the shift linkage. Full disclosure: I have a Ruf 5-speed in my car, installed by the PO, and I'm always trying to learn more about it. I never noticed the short bell housing before today, thus my inquiry. |
Ruf took advantage of that space to make a 5-speed out of a 4-speed transmission just like Porsche did with the 901 box, same dogleg pattern. The clutch cable is longer on the Ruf 5-speed than the 930 clutch cable since the transmission is moved back. |
Thanks, Ficke, yes, I need to think front-to-back and I had it backwards--the engine sits further back on the 3.3L cars, but the axles are in the same spot.
But as I think through this, I don't see how Ruf's longer nose (housing the 1st gear) didn't push the whole transaxle back. Here's the Ruf box from page one of this thread: http://forums.pelicanparts.com/uploa...1402413939.jpg And here's a short bell housing 930 box: https://www.cogscogs.com/assets/images/400-76-930.jpg As you can see, the dimensions of the housing are all the same, except for the nose. AND, the front transmission mount hasn't moved. I'm still confused (no surprise there!), but it sure looks to me like that longer nose would have to push the axles further back on the Ruf box. |
The front part (bellhousing) is short. Later 930 is 1.1' longer to cover the thick rubber disk
^ Yes, we know the engine sits further back on the later Turbos because of the longer bellhousing. We're all straight on that.
But look at the nose of both above, and where the tranny mounts are on both, and tell me the axles aren't pushed back on the Ruf box. That's what I'm trying to get my head around. Do the Ruf boxes use a modified transmission mount that pushes the gearbox forward? If so, wouldn't that require modifying the tunnel--unlikely, since that would open a big can of worms. |
Actually ya that’s a good question. The nose section on the ruf looks longer that the 1.1” additional size of the bell housing. And the long nose bellhousing 930 box hits the torsion tube when the standard mounts are left alone. That is this voodoo magic?
I'd suspect ruf used the center section from a G50 torsion bar tube to deal with the extra length.
Ahh I see.
On the 69-77 cars the axles were angled back for the new location of the stub axles to make the longer wheel base. Making axles angle to connect up is not a new thing or taboo for Porsche. |
Of course on the 78 ( different than on the 77 and prior 930) onward the motor was moved to the rear to compensate the longer bell housing. so could get a little room but not enough for the longer tail section. I have a 77 930 with the 930 4 speed into a 5 speed done by Andial. Can't see RUF embossed on the longer tail or investigated what else was changed as the 77 motor was not moved rearward until 78 so it would require a different installation than a RUF 5 spd going into a 78 or newer. Also not sure it is a RUF conversion as others have mentioned that the ability to convert was in practice before RUF. Also nice to know it may have 935 2-5th. I should investigate it up in the air against a stock 930 to find out more. I have owned it for close to 20 years and should know more about it. I talked to Dieter @ Andial about other things about the car a few years after I bought it but at the time did not get into the trans situation.
Thanks, Ficke, that's the second time today you've set me straight! Of course, the rear trailing arms locate the hubs and wheels and determine the car's wheelbase. I guess it's not a huge deal if the stub axles sit at a slight angle. I'm going to investigate this on my own car and see what kind of angle we're talking here.
And, for the record, the Ruf 5-speed is a really solid piece of equipment. |
Ruf box uses the stock 78 and up mounts and moves the axles towards the back. The shortened clutch housing makes up for the longer nose cone. Will not work in a 77 or earlier chassis.
| All times are GMT -8. The time now is 04:47 PM. |
