Are there any easy choices for upgrading the 4 speed in a 930?
Are there are any bolt up 5 or 6 speed transmissions for this car? I doubt I'd ever go that direction because it's probably too expensive and would devalue the car, but just for argument's sake, can it be done? I'm thinking a 6 speed in this car would be great, especially a sequential shift.
paging Uncle.. i think he was talking about Ruf five speeds for his car. wasn't cheap but not unattainable from memory
I put the G50/50 in my car. I did the camber boxes in the rear, as well as torsion bar delete and coilovers at the same time. All said the trans swap was about 12 grand (and that was 15 years ago)....
I talked with Patrick Motorsports a few weeks ago, and the tech I was talking to said the G-50/50 was getting as rare as hen's teeth... and if they had one to sell, it would go for about 25K !!!!!! |
For street use a shorter r&p is the best bang for the buck.
A friend that builds race transmissions made a few gear charts for the 4 speed and came to the conclusion that the 8:39 was so close to what he considered a good custom gear set up for street use it was cheaper to go with the r&p.
I would also think (just my .02) that if you went with a short 1-2-3, or 2-3 and kept the stock 4th you would have a significant rpm drop that would drop you out of the power band. |
Just a thought. With that said - I think a combo of the R&P and gears would do the trick depending on the use. I'm currently doing a G50/01 swap into my 86. It's not a cheap exercise. Chris. |
I had heard myabe it was rumors that the r&p options available were not too durable and that they might be questionable in terms of lasting as long as the stock unit.
Thats why I considered custom gears a better choice. I may be off base as its been a long time since I was looking into any of this. Can anyone validate whether there are r&p set options that would take the loads from the 930 engine that could be used in the 4 speed box? If so what gear ratio options are out there? ----Stock is a 9:38 ring and pinion thanks, Fred |
R&P may be a better option, I rarely drive it over 100 mph anyway. As is, it's not a big issue considering the engine has so much low end torque.... still it would be nice to have harder acceleration up to 100 or so.
Today I think your in the $2000 and up range for a r&p. Not sure what a used one goes for. In '07-'08 I paid $700 per gear (Guard)for our 915 race trans., not sure what they are today.
*Disclaimer* My 930 is built for VA country road / mountains driving. Minimal long distance highway use. After saying that....
Last year I was looking at short gearing choices for my 930 trans including replacing the R&P. The R&Ps are pricey and require specialized setup so it's not really any cheaper vs. buying individual gears. So I ended up moving the stock 3rd gear to the 4th gear position, then going with aftermarket short gears for 1, 2, and 3. California Motorsports did the work for me including sourcing the gears. The short gears have significantly minimized turbo lag and has simply made the car a blast to drive on the street. If I did a lot of long distance highway driving or track use I wouldn't have setup my trans up this way or I would have gone with a G50 5-speed. For me it's perfect! 1st GT 14:39 2nd Albins 20:34 3rd GT 24:29 4th (OEM 3rd) 28:25 http://forums.pelicanparts.com/uploa...1402331189.jpg |
Ruf 5 Spd,, What's in It?
So I also got to thinking the other night after a discussion around 5 speed transmissions for the 930.
A friend of mine really wants to do a G50 conversion but he’s really put off at the thought around the associated fabrication work, disassembly and having the G50 cut down, and additional work needed to the car for fitment., altering the torsion bar tube, addition the hydraulic line, and the pedal cluster and reservoir, the easy part. Lastly of course is the price. By the time you’re finish this mod you’re around $11k Then of course there is the infamous Ruf 5speed trans.. if you can find one. The last time I looked they were fetching between $8 - $10K depending on how fond of it the owner is. Over the years I’ve seen a couple of these up close and personal and visually they don’t look much different than our standard 4 speeders. The rear nose cone where the shift rod exits is the noticeable difference. The bell housing and center section appear to be the same and thus it appears that the 5th gear is added to that rear section requiring a specific redesign for the nose cone. Has anyone here actually seen the inside of this area on a Ruf 5spd, how different is it, and what would be the prospect of duplicating/ reverse engineering this old technology..the addition of a gear, slider, forks, lengthened rod.. what? And yes, the machining, modification, or casting of a nose cone…. |
I also had California Motor Sports rebuild and change the ratios of my gear box. Left 1st stock, changed 2, 3 & 4th. There was an altered R&P in, but it failed, I don't think it was set up properly, so I went to stock R&P. I'm quite happy with it now. Get about 1500 rpm drop between shifts.:)
Since the out put shaft has the Pinion gear it would be very expensive to change the R&P on a Ruf 5-speed. Ruf 5-speeds were great because Porsche did not have a 5-speed at the time that could take the power of the 930, but in today's world we have access to the G50. I would recommend using a shortened bell housing G50 and regulate the Ruf to the stop gap, interesting, historical, classic category and not a good answer for people who want bang for buck and versatility. I have a Ruf 5-speed in my car. http://forums.pelicanparts.com/uploa...1402413939.jpg http://forums.pelicanparts.com/uploa...1402414172.jpg |
Here are pictures of the 1st gear on the Ruf 5-speed
http://forums.pelicanparts.com/uploa...1402415030.jpg http://forums.pelicanparts.com/uploa...1402415086.jpg |
I would talk to Wevo. If there is enough interest he might, at least come up with some cost estimate to see if it's worth it to pursue. He's just finishing up a 5 speed conversion for the 356.
I would be interested if it is reasonable.
I went the G50/01 with my build, as others, I did torsion bar delete and notched my torsion tube.
I used these guys for info to get gear ratio charts. California Motorsports - Porsche transmissions, transaxles, gears, differentials, parts, service, manufacturing |
Guard still makes an R&P, but it isn't the 8:39 listed above. It is 8:41, so even shorter. Here's a ratio comparison:
9:38 4.22 8.39 4.875 8:41 5.125 Sounds too short for regular highway work. |
Your assessment is correct regarding the internals of the 930 trans.... and based on your comments, and from what I can see of the Ruf trans, the big difference remains the tail cover, and as you described, the lengthened output shaft, placement of/additional gears, and a few other details. Yes, a nice stop-gap for the time and probably still a viable retro-fit/option at present with a properly priced/reverse engineered kit. While the G50 is a nice upgrade, the level of work, cost, etc.. required for an install is not for everyone. Based on the items described above, if this were available in kit form to the 930 owner, it would be little more than a thorough trans rebuild. Quote:
80's. |
I did a G50/01 upgrade last year.
Shortened the bell housing, so That I could use my torsion bars. Modified the transmission mount so a did not have to weld new mount to the chassis. Can switch back to 930 transmission any time if I want to. A great upgrade over the 930 transmission. |
Just found a great deal on an old stock 8:41. Will let you know how it goes after I find an LSD and install them both.
Andial told me that they did not sell the 8:41s, because they are noisy. A search on Rennlist and Pelican might lead you to think the same. BTW, ignore what I said on Rennlist about SC-spec cams. I now think that they are wrong for a Turbo for the street. I will be restoring the original 930 cams in my car. |
^ I've heard similar. Figured it was worth a shot. Matt Monson at one point told me that a noisy ring gear can be managed somewhat with meticulous setup and friction coating. That was a generic statement so unsure if it applies to this this of RnP.
Albins make a taller (10:31) R&P for the G50 - CMS carry it; I considered it.. It was $3000 US at the time, Factory G50 gearsets are $900 per gear (1st involves re-welding the shaft as well).
Last I looked, core, non-broken G50/50's were reputed to be $10K - if you could find one. Good luck with that, they didn't make many, and most are either in the original car or already in an Ultima or GT40 rep... I think you have to figure a used transmission with any mileage as "suitable for rebuild", especially for high-power applications. The G50/01 with 100K I used ate about $3000 worth of factory wear parts (bearings, bushes, seals, synchros etc) before it got anything trick - and it came out of a great-driving car (shop I bought the box from had been looking after it for 10 years) that got hit in traffic. After the tall 5th I had in the 915, stock 911 G50 5th was also WAAAY too buzzy on the freeway. |
Resurrecting this thread, as there is a Ruf 5-speed up in the "911 Used Parts" forum: http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1067548-genuine-ruf-5-speed-btr-box.html
I noticed that the Ruf 5-speed has a short bell housing, like on the early 3.0 Turbos, which would shorten the wheelbase of the car, wouldn't it? I presume that was so the longer "nose" of the transaxle (where Ruf stuck the extra 1st gear) would still sit at the proper location to attach to the shift linkage. Full disclosure: I have a Ruf 5-speed in my car, installed by the PO, and I'm always trying to learn more about it. I never noticed the short bell housing before today, thus my inquiry. |
Ruf took advantage of that space to make a 5-speed out of a 4-speed transmission just like Porsche did with the 901 box, same dogleg pattern. The clutch cable is longer on the Ruf 5-speed than the 930 clutch cable since the transmission is moved back. |
Thanks, Ficke, yes, I need to think front-to-back and I had it backwards--the engine sits further back on the 3.3L cars, but the axles are in the same spot.
But as I think through this, I don't see how Ruf's longer nose (housing the 1st gear) didn't push the whole transaxle back. Here's the Ruf box from page one of this thread: http://forums.pelicanparts.com/uploa...1402413939.jpg And here's a short bell housing 930 box: https://www.cogscogs.com/assets/images/400-76-930.jpg As you can see, the dimensions of the housing are all the same, except for the nose. AND, the front transmission mount hasn't moved. I'm still confused (no surprise there!), but it sure looks to me like that longer nose would have to push the axles further back on the Ruf box. |
The front part (bellhousing) is short. Later 930 is 1.1' longer to cover the thick rubber disk
^ Yes, we know the engine sits further back on the later Turbos because of the longer bellhousing. We're all straight on that.
But look at the nose of both above, and where the tranny mounts are on both, and tell me the axles aren't pushed back on the Ruf box. That's what I'm trying to get my head around. Do the Ruf boxes use a modified transmission mount that pushes the gearbox forward? If so, wouldn't that require modifying the tunnel--unlikely, since that would open a big can of worms. |
Actually ya that’s a good question. The nose section on the ruf looks longer that the 1.1” additional size of the bell housing. And the long nose bellhousing 930 box hits the torsion tube when the standard mounts are left alone. That is this voodoo magic?
I'd suspect ruf used the center section from a G50 torsion bar tube to deal with the extra length.
Ahh I see.
On the 69-77 cars the axles were angled back for the new location of the stub axles to make the longer wheel base. Making axles angle to connect up is not a new thing or taboo for Porsche. |
Of course on the 78 ( different than on the 77 and prior 930) onward the motor was moved to the rear to compensate the longer bell housing. so could get a little room but not enough for the longer tail section. I have a 77 930 with the 930 4 speed into a 5 speed done by Andial. Can't see RUF embossed on the longer tail or investigated what else was changed as the 77 motor was not moved rearward until 78 so it would require a different installation than a RUF 5 spd going into a 78 or newer. Also not sure it is a RUF conversion as others have mentioned that the ability to convert was in practice before RUF. Also nice to know it may have 935 2-5th. I should investigate it up in the air against a stock 930 to find out more. I have owned it for close to 20 years and should know more about it. I talked to Dieter @ Andial about other things about the car a few years after I bought it but at the time did not get into the trans situation.
Thanks, Ficke, that's the second time today you've set me straight! Of course, the rear trailing arms locate the hubs and wheels and determine the car's wheelbase. I guess it's not a huge deal if the stub axles sit at a slight angle. I'm going to investigate this on my own car and see what kind of angle we're talking here.
And, for the record, the Ruf 5-speed is a really solid piece of equipment. |
Ruf box uses the stock 78 and up mounts and moves the axles towards the back. The shortened clutch housing makes up for the longer nose cone. Will not work in a 77 or earlier chassis.
