Need help setting up my WUR
Hi guys from what I understand I
I first set my cold and warm pressure then set the co or afr to 3 or 13.38 with o2 disconected here are my questions
1-should I disconect the o2 sensor
When setting cruse afr?
2-What is considered cruse ,5th gear at 65 mph?and what to aim for? And I adjust the warm pressure to get where I need it to be
3-i set my rpm swith to 3900 rpm I have a k27 hybrid / bob exhaust and andial I/C and wastegate set at 1 bar
I now go full throttle in what gear ?
Erick
Old 07-23-2014, 11:24 AM
Metal Guru
911nut's Avatar
You set cold cp, warm, cp, then boost cp, double back and check everything.
I eliminated the narrowband O2 sensor when I installed headers. The emission system is very primitive and I felt that my car ran better in open loop.
If you have the O2 sensor connected it will set you to 14.7/1 at cruise anyway.
Otherwise, if you are using longer duration cams then stock and you ditch the O2 sensor, a little richer is good but I mean 14.0/1.
Sounds like you have a 5 speed transmission, correct? If so I'd recommend that you do your data gathering pull in 3rd gear so you actually get some load on the engine.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 07-24-2014, 04:49 AM
T77911S's Avatar
you set warm CP first. then set cold the next day
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-28-2014, 10:43 PM
