-   -   Trans sensor ID help (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/831972-trans-sensor-id-help.html)
2TT930 09-30-2014 05:02 AM
Unfortunately the wires for this got hooked up on the axel of the way out and it was too late when I noticed.
I can't find any info on it or find it for sale anywhere.
What is it for?
Interesting thing is that the wires appear to not even have been connected anyway.
I can easily solder the wire back into the connected but I don't know which wire connects to which side of the connector.
Car in questions is an 85 930
Will post pic shortly.
2TT930 09-30-2014 05:04 AM
http://i95.photobucket.com/albums/l1...B173C55175.jpg
xbmwguy 09-30-2014 06:01 AM
thats your reverse light switch. get a new one solder a new female end on and your done.polarity doesnt matter
2TT930 09-30-2014 06:22 AM
Thank you very much!
16Volt 09-30-2014 09:46 AM
Hah, we have identically broken switches.
2TT930 09-30-2014 07:51 PM
I'm just going to try and solder it and hope for the best. I dont think the wires were even connected before. There looks like there was supposed to be a connector there and its def not on the floor under the car.
JJ 911SC 10-01-2014 02:53 AM
Originally Posted by 2TT930 (Post 8285875)
... I dont think the wires were even connected before...
Unless someone tell you you back up light does not work, you would not know it.
Miguel Antonett 10-01-2014 05:22 AM
^^^ or, if you try to back up in the dark...
How often do you guys check into things like that - walk around the car... (i.e. headlights, turn signals, backup light, horn, tire pressure, look under the car before a spirited ride being sure there is nothing hanging down...)?
2TT930 10-01-2014 07:44 AM
I check normal things frequently.
But I honestly dont care at all about the reverse lights so I have never taken the time to check.
