Dyno gurus, I have a question....VIDEO
So, I finally got to the dyno today, but it didn't work out.
From 4K to over 6K, the graph did not plot at all. Question is, does ignition "flame-out" cause the Dynojet to not read out? I've had a flame-out issue or ignition cutout since I went to 1.4 bar of boost probably linked to my 20+ year old coil pack. This system only plots hp, so it makes sense that missing RPM from cutout would prevent the correct calculations for hp as the computer has nothing to work from. Vid showing 1 of 3 runs.......all with similar readings missing and erratic readings. 3.4L BW S366 @ 20PSI - YouTube Anyone experience this? Couldn't find anything on the web. |
On any of the DynoJets I have used, loss of RPM signal would default to a torque vs. road speed graph. I would guess that they could be configured to do other things under those circumstance though. If you hunt around enough in the software, your torque vs. road speed data should be stored in there somewhere and you can interpolate it to RPM if you so desire.
Hmmm, too bad it wasn't at a shop to try to figure out another method to generate the correct numbers. :( |
What's going on with that semi surge before full boost? Are your AFR's linear on boost? Your running wasted spark? Plug gap? This only started happening when running 20psi?
Wasted spark with Ford EDIS ignition. Plug gap is 0.025". And yes, once it ran a Holset HX40, I kicked up boost from 1 to 1.4. It happened (hard hitting surge) around this time IIRC. |
What are you running for fuel? And what size injectors? And what is it reading for AFR at 20? Did you ever load that timing map I sent you?
In order of questions:
93 octane, 80lb Dekas, 11.7 AFR, no I did not. Let me revisit. |
Try fattening it at 20 just a tad.
Just a tad 11.5, no need to flood her...
Does it behave the same at 18psi or is it just 20?
I had a flame-out problem a while back it end up being the plugs were too cold (BKR9EIX I like these as they have 5/8 hex instead of 13/16). I had this happen running NGK iridium's but went back to Bosch Silvers. I think if I would have dropped the range to 8's in NGK it would have netted me the same results which is what I'll try next set BKR8EIX stk#2668
What do you recommend from NGK? I'm not a fan of the Bosch tax.... :) |
What plug (stock number) are you running now? Your single plug?
Single plug. I believe I went one range colder over what the Pelicanites recommended for a stock Carrera 3.2.
SKU: #BPR7EIX ITEM : # NGK4055 This is 1 range colder than stock. Typically 1 range for every 100 HP over stock. You could run 8's. 8's are equivalent to Bosch 3's
8's, I believe I'm running.
BKR8EIX stk#2668 is the info for 8's. good for 200+ over stock. 9's are just too cold for even over 1100HP on toasty Florida days. I think even Goran had issues with 9's over on his side of the world. It is much cooler there. Either a crotch rocket shop typically stocks these but at a premium. Or buy off eBay for a song & dance.
Well, no dice again. Dyno owner invited me out again for a redo.
This time, it read 730ft/lbs in 2 back to back runs. I said, "I think that's a little optimistic"! HEHE. As much I wish it was, that would be nuts. Next two runs showed in the 360 range after he clicked on something. Uh, WTH is going on?! After reviewing, I noticed the MPH he is showing stops at ~95 MPH while I do mid-130's in 4th. If I factor the difference between ~95 and ~135, and multiply by the 368 number, that puts me in the low-500 range. Am I on the right path, or totally off? I'm going elsewhere after this! |
You sure you aren't getting wheel spin? A DynoJet is inertia based and it is quite possible to get erratic readings with wheel spin. I have had this problem trying to dyno Cup cars and the only solution was to strap them down to the dyno, not just fore and aft. They could rev out faster then they had grip to spin the roller. The hub based DynoPack dynos seem to be popular with the turbo tuner crowd as they eliminate the possibility of tire slip.
If your torque curve were linear, and those numbers were accurate, you could extrapolate out to that but I suspect that it tapers off at some point or at least stops increasing and with all the issues you have been having with this dyno, I wouldn't put much faith in the number. |
What do you say about the MPH being off?? |
I do have one-wheel-peel, and that makes sense since it only read ~95MPH at redline when I do closer to mid-130's? No?
Jerry Aikman operates a dynapack dyno in Cedar Park down the road from you...
aikmanperformance.com |
Another question.
When I asked for the run to be in MPH instead of RPM (in case ignition was issue), the final MPH was listed as 90-95MPH. It'll do 130+ in 4th, the gear it was ran in. Does that indicate wheel spin???? |
You are getting wheelspin in that video.
Just my opinion. |
Ignition crossfire will freak out a Dynojet.
But, the 90-95MPH was another thing I felt lent to wheelspin. |
It may not be a dyno queen but damn that thing sounds good.
We have ignition pickup issues with our dynojet at times. Some times just flip the pickup on the wire takes care of it. I have switched to a optical and its rock steady. I rarely have a issues with tire slip but it did sound like tire slip in your video.
You got victimized by a bad strap down job - That thing spun hard. The rear axle centerline needs to be a couple inches in FRONT of the dyno roller centerline so that when it loads up hard it is actually pulling the tires into the roller harder. What I saw in that vid was just the opposite.
You can easily see a wheelspin issue by plotting roller speed (MPH) vs RPM. With no spin or slip this will be a straight line. |
Didn't know about where the tire is supposed to be either. We kind of vowed not to use this guy anymore. Friend had issues too. |
| All times are GMT -8. The time now is 10:15 AM. |
