-   -   930 will not stay running. (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/838899-930-will-not-stay-running.html)
rufporschecar 11-16-2014 05:57 AM
I have an 81 930 that will turn over but will not stay running. It cranks then quites, cranks then quites. It will run about 3 seconds. What do I need to do to fix it.
dporsche74 11-16-2014 07:45 AM
outta gas?? bad fuel pump perhaps :D
rufporschecar 11-16-2014 10:08 AM
It has gas and the pumps sound like they work
Strygaldwir 11-16-2014 03:29 PM
It is a little difficult to tell without more information, but I had similar symptoms. Mine would start, then die in about 3 seconds. I found that if I held the metering plate down, it would continue running. I then got a pressure gauge to measure the cold control pressure. This show WAY high. I took the Warm Up Regulator (WUR) out and disassembled and cleaned it. I then measured the cold control pressure. It measured 1.5 BAR at 50 degrees F. This was within the range for my motor. I then started the car and it continued running.
Not well, but I have narrowed that down to a vacuum leak. New hose comes in tomorrow.
Good luck.
Miguel Antonett 11-17-2014 01:15 PM
+1 on the metering plate free travel checking... sometimes it gets gummed up creating those symptoms.
930 slant nose 11-17-2014 01:31 PM
you want to sell the headache ill buy it
rufporschecar 11-17-2014 07:02 PM
If you are serious I will sell it.
T77911S 11-18-2014 03:25 AM
pushing down on the sensor plate adds more fuel to richen the mixture. if the cold CP is too hi doing this will help to show that if you dont have gauges.
the inlet screen to the WUR can get dirty and clogged raising the control pressure.
could also be an air leak, which leans it out and once again pushing down on the sensor plate will help keep it running.
i know it was said, but out of gas WILL do the same thing. you would not be the first to troubleshoot a non running car that is out of gas.....and looking in the tank can be deceiving.
930 slant nose 11-18-2014 12:41 PM
pm sent
