-   -   Time to upgrade Jeff NJ's 930 (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/845988-time-upgrade-jeff-njs-930-a.html)
Jeff NJ 01-08-2015 09:23 PM
So last spring I started a thread about what my options were to upgrade my car here: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/806512-lets-upgrade-jeff-njs-car-thread.html
Got lots of great advice and talked to a bunch of great people about it. I've had my 930 for just over a year and have put almost 3000 glorious, ***** eating grin miles on it. My clutch has been giving me some issues as I can't get it into reverse when the engine is warm without grinding the hell out of it. I replaced all the stuff outside the motor (omega spring, cable, pedal bushings, etc.) to no avail, so its time to pull the motor and see what is wrong with the clutch. I am thinking either the shift fork is worn or bent, or the pilot bearing is failing. Either way, motor is coming out and I figured while I'm in there, time to upgrade! I'll also be changing a bunch of leaky gaskets and seals and some other "while your in there" maintenance items. Everything coming off is getting boxed up and packed away in case the car becomes more valuable in stock form if I ever sell.
I have everything disconnected from the motor and am ready to drop it. Some friends are coming over Sunday to help with the drop, so hopefully I'll have pics of the motor out by Sunday night!
Here is what I'm doing:
  • K27HFS turbo - bought it from a member here!
  • TurboKraft half bay long neck Intercooler. Black anodized.
  • RarlyL8 headers with heat.
  • B&B muffler - cat delete, single out. Sounds great. Already installed. Purchased here from a member.
  • BL WUR - Brian is back in business!!
  • Tial 46 mm Waste gate. Not sure what spring I'm going with.
  • PLX wideband AFR gauge and boost gauge.
  • Wevo Short shift kit. This is already installed and I love it.
  • Rebel Racing engine mount and motor and trans mount bushings.
  • Suspension refresh -sway bar bushings, trailing arm bushings, control arm bushings, drop links. Probably getting the Bilsteins re-valved.
  • Fuel line replacement - speaking with Len about this now. Nothing wrong with mine, but I figured it was time. Much easier with the motor out.
  • Valve adjustment - no idea when it was done last. Will inspect the rockers, arms, valves, head studs, etc. while I'm in there.
  • All the suspension, gasket, and other assorted parts were purchased from our host whenever possible.
I'm hoping for about about 400 HP compared to 282 stock and considerably more torque too. Opinions on HP/TQ gains? I am planning on dyno'ing it once I'm done to validate the butt dyno. Should be a fun and educational winter project. I am a little nervous about my first engine drop, but I know that the brain trust here will help to get me through any issues that come up that are beyond me.
Here are some pics of the parts along with some before I started and where I am now shots. Headers and Tial are not here yet, so those pics will have to wait. Brian is almost done with my headers!
I figured I would post up as I make progress with some pics (engine out, clutch inspection, parts install, etc.). This will take me a while, but I have all winter, so I'm in no rush.
Wish me luck!!!
http://forums.pelicanparts.com/uploa...1420779349.jpg
http://forums.pelicanparts.com/uploa...1420779441.jpg
http://forums.pelicanparts.com/uploa...1420779463.jpg
http://forums.pelicanparts.com/uploa...1420779569.jpg
http://forums.pelicanparts.com/uploa...1420780066.jpg
http://forums.pelicanparts.com/uploa...1420779746.jpg
A bunch of stuff that I've removed so far:
http://forums.pelicanparts.com/uploa...1420779787.jpg
Here is what it looked like before I started:
http://forums.pelicanparts.com/uploa...1420779852.jpg
Here is where I'm at now:
http://forums.pelicanparts.com/uploa...1420779872.jpg
http://forums.pelicanparts.com/uploa...1420779890.jpg
dos531 01-08-2015 09:43 PM
Sounds like a fun build. Seems like your 400 crank hp is in the ballpark. I know my car made about 330whp when it had a k27. A J&S safeguard would give you some peace of mind especially since you're increasing power and have it apart already. Cheap insurance after all the money you've already spent.
jwasbury 01-09-2015 04:33 AM
You're going to be busy thus winter. Don't worry too much about the absolute hp#...the combination of all this work, both engine and suspension, is going to completely transform your car. Your $hit eating grin is going to get much bigger. Do not get greedy with boost level, and do verify that your distributor functions properly. Check total advance, and check that the timing is properly retarded under boost pressure.
Not sure where in NJ you're located, but if I can offer any tools or moral support do let me know.
b5aar 01-09-2015 06:59 AM
Nice....looks similar to what I was doing last year! no suspension though....
Some random thoughts
Lots of threads on engine drops - make sure you have the jacking/stands height to get the engine clear - dont forget the Bosch multi pin connector to the right of the driverside shock mount
Looks like you've spoken with Chris - TK sent me a "Do all these gaskets/seals when engine is out" package, front rear main seal, oil sender, breather etc
I also replaced the stock injector blocks with TK billets
May need some cams to get to the HP goal - level of difficulty higher
Check/replace engine compartment seal while your in there
Check air box clearance with the IC - may need cone filter
k27 vs LDZ mounting and orientation
Air injection system - leave in or out....
How about an MSD ignition/coil...plug in to your existing harness no cutting...JFairman has some good thread and pics I used
Assuming you have K-Lambda system with oxy sensor....... if keeping.....after reassembly make sure ground wire on inner stud for fan housing is solid....caused all kinds of problems...thanks Ronnie for troubleshooting
The voices in my head have stopped..................Beautiful 930....Have funhttp://forums.pelicanparts.com/uploa...1420815520.jpg
930/66 01-09-2015 01:51 PM
Hi Jeff
Good Luck!
First i have to say the Customer Service from Chris is nice!
I see you have the IC from Chris, maybe you will have the same problems as I with the fitting.
#1 conflict with the air filter box
#2 connection to supplementary air slide wrong
#3 Connection to the turbocharger intercooler welded wrong (can`t close my tailgate)
Ask Chris for a solution he is absolut helpful
kenikh 01-09-2015 01:59 PM
You're on the border of a high performance clutch upgrade. When I did my motor, I ended up with an unbudgeted $2500 surprise. The Sachs BTR clutch and adapter is the only option for high performance engines that retains light pedal effort. Be wary.
OldSpool87 01-09-2015 02:07 PM
Jeff- happy to hear you are making the mods you wanted just a year ago!
I have the black TK IC. It's fantastic and keeps a "stock" feel to the engine bay. You will need to notch the air box or go the cone air filter route. I'll sell you my cone filter if you want it b/c I went the notch route.
Also, my mods are nearly the same. I did include a lightweight pressure plate and Sachs clutch. Big difference in revability (that's a new word).
Props for taking on the drop!
Good luck
Will
Jeff NJ 01-09-2015 03:31 PM
Thanks!
I'm going to look into the J&S. Probably a dumb question, but would an MSD6AL have a knock sensor and provide similar protection? Or can they be used together? I'm on the fence about MSD...
Jeff NJ 01-09-2015 03:38 PM
Thanks Jake!
Yeah, I'm not too worried about the actual HP. It's more to validate the gains via the upgrades.
I am thinking either .8 or .9 bar spring. On their website, Tial states to get .3 bar lower than the desired boost when you have aftermarket headers due to lower backpressure. So I guess a .8 spring would really be 1.1bar? Is that correct?
Thanks for the offer. I think I have the right tools (we'll see...), but I do see me picking your brain on occasion. I read your motor rebuild thread and it was great. So much good info in there. I'm hoping I don't need to go that deep. I am in Morris County (probably 45 mins from the Holland Tunnel.)
Jeff NJ 01-09-2015 03:41 PM
Yeah, I've already budgeted for a clutch. I'm just waiting to see what I've got in there before I buy anything. It was replaced by the prior owner, but the receipt doesn't state what, exactly was replaced, or what brand it is, so who knows what I've got... Eyes wide open and hoping for the best.
Jeff NJ 01-09-2015 03:49 PM
Lots of great points here! Most of them are already accounted for in my head, but I appreciate all the info and let me know if you think of any other tidbits.
Chris at TK was very helpful. Lots of good tips.
Brian at Rarlyl8 helped me with the k27 mounting.
Engine compartment seal looks fairly good from what I have seen, but will replace if necessary.
Air injection is going.
K-Lambda may be going.
Not replacing cams (this time)
Not sure about MSD. Would it help with my build?
thanks!
dos531 01-09-2015 04:03 PM
Originally Posted by Jeff NJ (Post 8432643)
Thanks!
As far as I know MSD doesnt offer anything like the J&S in terms of knock control. I think the only knock related item they sell is a sensor which activates a light and makes a noise when knock is detected, whereas the J&S will hear the knock before its even audible and pull the timing on individual cylinders before any damage can occur. They can be used together with the MSD replacing the CDI, but it would be redundant as the J&S offers most of the same features as the MSD. The 6al2 programmable will offer a bit more control over timing since you can create a custom timing curve, but in my opinion the knock control is more important. They both have the ability to pull timing vs boost, which is really helpful. On my car I have the distributor advanced a lot more than factory with the j&s pulling timing at full load. This way I have much more timing off boost which makes it much more responsive in those situations, but still safe at full boost.
I dont work for John at J&S or anything, i'm just really happy with the system on my car so I try to spread the word. I can finally take my eye off the AFR gauge while driving since I know even if there's an issue the J&S will protect my motor. He's very helpful too if you have any questions. I exchanged probably 20 emails with him before I ended up purchasing the safeguard.
redturbo911 01-09-2015 05:22 PM
Nice progress so far. Keep the pictures coming.
jwasbury 01-09-2015 07:43 PM
Jeff,
Couple things...I noted my max boost dropped when I installed higher performance exhaust (mine is an SSI system). Rather than change wastegate springs, I just put in a manual boost controller. The "dial-o-death" knob is in the engine compartment, so I don't have temptation to crank it up as may happen with cockpit adjustability.
Regarding clutch, my car had a basically brand new OE pressure plate and standard Sachs spring center clutch disc. I have no slippage issues, and that's with something around 375 wheel HP. YMMV.
For brain pickin' just PM me sometime and I'll give you my cell number. If you're ever near to Jersey City, look me up. I'll show you my little workshop and current project:
http://asbury.smugmug.com/By-Land/Ra...18095162-L.jpg
krasuskyp 01-09-2015 09:07 PM
nice Jeff - way to jump on in there
as was said, what you've got planned will literally transform your car from awesome to uber - drivability increases immeasurably (regardless of dyno measurements), and your satisfaction / gratification will be immense
best is the sense you'll establish with your car - you'll learn much about it, and you - good stuff
I def yoinked ^said^ Bosch multipin connector by the inner / left shock tower, got caught up in the haste of trying to have 1000hands @ the same time whilst disconnecting / lowering things
my thoughts were largely covered above, but random thoughtlessness:
engine sound pad scrape-age and/or replacement is good while yer in thar - yers looks as insipid as mine
as is engine seal - you'll be surprised how brittle/dry you'll find yers is, all over but most especialliest by the turbo - replace it
recondition yer tin too a bit whilst it's out - check for rust by turbo
def consider cams - you're right there, doin valves, just a special tool (Ronknees' nickname?) away from 'em - why not. My SC's really changed the overall character of my powerband, almost want to say the gearing feel too... lovin it.
plus
you get to attend to some good leakprone sealage too whilst at it... chain covers, chain box, cam ends, etc. (and be like me and have something still leaking now afterward - awesome!) http://forums.pelicanparts.com/suppo...leys/silly.gif
RSR rocker seals - $80 well spent
do the rear breather coupler hose whilst in thar, and any / every seal you can get to... oil cooler, oil pump, oil tstat, turbo / muffler / wastegate, etc.
I v-banded my turbo / muffler flanges whilst out - non-eggzachry lined up tips (and tits too, for that matter) ultrawicked urk me... v-banding is smart easy cheap flexibility
lube yer throttle linkage thoroughly whilst you have access to it
new vacuum hosiery
if you do go cone filter, DO add a catchcan - venting to atm FTMFL!!! (reference the Bongresin in my Cabin Fever thread - Just Say No)
invest in Massenguil and rags and douche the beejeebus out of everything
mebbe set aside some polishing time - I love me some nekkid aluminum smiling at me, I'm not a powdercoater... au naturale baby
change gear oil, trans tailshaft seal (mine was leaking into the tunnel box pretty visibly @ 60k)
jah... clutchslippage... I'm there now... 20k on OE spring centered clutch then increasing to ~420+chp has mine slippin somewhat...
by the book / read it
Lookin forward to updates! Def take Jakester up on his offer fer tewls / wisdom / etc... he's encyclopedic with his P-wrench knowledge and assistance, and always is a voice of blunt realism
krasuskyp 01-09-2015 09:22 PM
ps. I went MSD... seemed to make good sense
pps... remove / store all OE parts to preserve value
or sell them all for the difference in value you'll not receive later down the road
was a no brainer for me... half my mods cost me literally zero... hmmm
plus
knowin my bits were doin someone out there some good (errrrrrr) rather than collecting mold 'n rust on the shelf? Priceless. Just sayin...
Ronnie's.930 01-09-2015 09:53 PM
Paula, I've got yer "special tool" right http://www.sherv.net/cm/emoticons/ha...y-emoticon.gif, bub!
Two minutes, three times daily = Paul's errrr ummmm "polishing" regimen!!!
Jeff, sweet project(s), and like other's have said, when you next drive the car, you'll be saying "stock is fer Paul's Christmas gifts"!!!
b5aar 01-09-2015 10:15 PM
The MSD is good for availability and cheaper replacement. 30 k miles without problem on mine. Some opinions on bigger spark gap etc. I have the programmable for some 2D mapping in the future. Lot of lower end gains based on others experience. Havnt had a chance to try yet.
I like my klambda....runs cleaner and little better gas mileage when I'm not hammerin on it.
As Paul said, cam upgrade is nice..better off boost driveability and more power everywhere.
TK set me up with a KEP pressure plate and SACHs organic disc...little more pedal effort and grabbiness but lot of grip and no issues after 10k+ miles
In the slippery slope category.. This might be the time to go through the gear box..
Also take extra care when mating the gearbox to the engine on reassembly...make sure the release fork pivots in back of and sits on the throwout bearing tabs correctly
Jeff NJ 01-11-2015 03:03 PM
So the motor is out!! Went very smooth, mostly because of all my prep work that I only would have known about from here. Thanks for all that have posted engine drop threads in the past!!
http://forums.pelicanparts.com/uploa...1421016825.jpg
http://forums.pelicanparts.com/uploa...1421017007.jpg
http://forums.pelicanparts.com/uploa...1421017026.jpg
So my first order of business was to check the clutch since that was the primary reason for the engine pull. Got the trans separated without issue. Clutch fork looked good. Pressure plate looked OK to me.
http://forums.pelicanparts.com/uploa...1421017106.jpg
Time to pull the clutch to see what that looked like. I'm not sure, but I think this may be an issue...
http://forums.pelicanparts.com/uploa...1421017142.jpg
http://forums.pelicanparts.com/uploa...1421017155.jpg
So I'm quite shocked that I was able to drive this at all with the clutch the way it is. I already budgeted for a new clutch, so not a big deal. Suggestions for a new clutch? I want stock clutch pedal feel if possible. I don't track the car and I don't see me going over 400 hp at the flywheel. (famous last words)
kenikh 01-11-2015 03:38 PM
At that power, if you want stock pedal feel, my previous warning applies...Sachs BTR setup.
speednme1 01-11-2015 04:10 PM
Jeff have a fun and safe project. Now that the motor is out it would be a good time to modify the fuel head and add bigger fuel lines. Will be a plus with the bigger intercooler and the adjustable wur.
mussberger 01-11-2015 04:41 PM
Headers, bigger intercooler, bigger turbo and no cams? You may be disappointed.
Replace those compartment seals (they look perished) its very easy to do now and not much money in the grand scheme of things.
TurboKraft 01-13-2015 11:14 AM
+1. It's the clutch to use. We can help you with that.
Without looking at specific build dates, I think that intercooler was not of the batch that had fitment issues. If you encounter any problems at all during installation, something is wrong, I'd like to hear about it and we'll correct it.
TurboKraft 01-13-2015 11:18 AM
Engine compartment seals & sound pad.
A peripheral re-seal addresses most of the oil drip issues of a 930 engine, quite easy to do with the engine out.
Tippy 01-13-2015 12:38 PM
I cannot find this in a search. What is it? Link?
TurboKraft 01-13-2015 03:04 PM
TurboKraft Inc : Clutch Pressure Plate : Lightweight HP 594 [88 3082 999 594] - $1,195.00
It has a big brother, the 934 pressure plate, used in the 4-speeds before Porsche started flipping them upside down. It's what we used in Tom's UBER930 to withstand 600tq at the wheels.
Lightweight 935 Clutch
Tom wasn't a young man, nor the biggest guy, and he felt the clutch effort was surprisingly light for its strength.
So no worries about having a super stiff pedal that's unpleasant if/when stuck in traffic.
Black_Hat 01-13-2015 05:04 PM
After slip issues on my prior Porsche build
I went with the Sachs Race Engineering PP PN# 99 3082 999 764
Sachs data sheet claims good for 890Nm and 659 lb/ft
I'm using a RS organic spring clutch, might not gt max bite with the RS disc but VERY streetable in fact smooth on the street, like stock
and for my application , no hint of clutch slippage
in fact everything else breaks loose instead
1991 C2 turbo
Tippy 01-13-2015 06:42 PM
<a href="http://turbokraft.com/catalog/product_info.php?cPath=&amp;products_id=200" target="_blank">TurboKraft Inc : Clutch Pressure Plate : Lightweight HP 594 [88 3082 999 594] - $1,195.00</a> <br>
<br>
It has a big brother, the 934 pressure plate, used in the 4-speeds before Porsche started flipping them upside down. It's what we used in Tom's UBER930 to withstand 600tq at the wheels.<br>
<a href="http://www.turbokraft.com/gallery/v/911-930/Tom+930/Engine+Build/Lightwight-Clutch_TurboKraft-930-Tom.jpg.html?g2_imageViewsIndex=1" target="_blank">Lightweight 935 Clutch</a><br>
<br>
Tom wasn't a young man, nor the biggest guy, and he felt the clutch effort was surprisingly light for its strength. <br>
<br>
Will this work for a G50/01? Assume no.
Jeff NJ 01-15-2015 03:36 PM
So my fuel injectors are not spraying a very good pattern. I have soaked them in Techron for a few days, blew them out from the injector side using JFairmans method and a few of them are not good. I will soak them some more, but if I have to replace them, should I get the stock 017 or the Euro 009. I really don't want to go with a euro fuel head, cams, porting intakes, etc. for budget reasons. I believe I will be happy with the HP produced by my proposed upgrades. However, if I have to replace them anyway, does it do any good to go with the euro 009s if I don't do anything else to the fueling, or am I just wasting money, since they are more than the 017s?
thanks
kenikh 01-15-2015 04:08 PM
The rumor is that the CIS injectors for the Mercedes 560SEL are a good alternative...and only cost $60/ea.
Jeff NJ 01-15-2015 04:20 PM
Is it the same as the 009 or the 017? I can buy the 017 for $58 online. The 009's are $102, so if I need them, I would only get the 009's if there was a benefit to doing just that.
thanks!
RarlyL8 01-15-2015 05:11 PM
The -017 may flow enough for your application but I always go for the -009 as you want to change those once and done. New injectors are an overlooked cure of many CIS ills. Your engine will fire quicker, idle smoother and throttle response is quicker.
krasuskyp 01-15-2015 07:15 PM
how many miles, Jeff?
>sticks fingers in ears la la la la la la<
Jeff NJ 01-15-2015 10:35 PM
60k miles Paul. I'm not surprised they aren't good. 26 years and 60k miles and those tiny little screens have to be clogged. I wish they were rebuildable.
Jeff NJ 01-15-2015 10:43 PM
The triangle of death!!
http://forums.pelicanparts.com/uploa...1421390484.jpg
Got everything off. Now to clean the motor and adjust the valves.
http://forums.pelicanparts.com/uploa...1421390511.jpg
krasuskyp 01-16-2015 10:17 AM
fuuuuuuuuuuuuuuuuuuuck... eggzachary me miles here too... sigh.
Denial... ain't just a river! ;)
Jeff NJ 01-16-2015 10:33 AM
What is interesting is that the internals of the intake manifold, the fuel head, the lines and connectors are all SPOTLESS. The insides look as clean as the day it came off the showroom floor, so I would like to think that the car didn't sit for years and good gas was always used. Even so, the injectors are not flowing well.
jwasbury 01-16-2015 11:12 AM
Re: injectors...I replaced mine while chasing a light throttle misfire (which turned out to be an ignition timing problem). I did the seafoam soak and backflush and felt that the spray pattern could be better, so figured WTH. $600+ dollars later, I can't say I noticed a damn bit of difference. Not sure it was worth it other than piece of mind. I've kept the old injectors because I suspect they are ok. IMO unless you have the proper equipment, I don't think you can correctly assess the health of your spray pattern. Just one guy's experience doing the DIY test in the garage with an air compressor.
pkabush 01-16-2015 09:26 PM
There's a pretty simple test that's outlined in the factory manual. Also some good vids on youtube. IIRC you pull all six injectors, hook the fuel lines back up, put each injector in it's own glass jar, crank the engine for ? seconds and measure the amount of fuel.
I guess this wont give an accurate assessment of spray pattern but it will show any week or defective injectors.
Jeff NJ 01-16-2015 10:30 PM
So do they state how much fuel should be in each glass after X amount of cranks or time? If they are totally different volumes in each glass, there is obviously a problem, but if they are all roughly equally clogged, would you be able to tell with this test?
I don't want to spend $600 if I don't have to...
