Air filter replacement for my 930
Hi have the following air filter from Fabspeed on my 81' 930, which is broken so I'm trying to replace it. It's almost $300 new. Anything else that could directly replace for cheaper? I have aftermarket intercooler and other stuff so the stock would not work.
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... |
Banned
This fits perfectly and many on this forum use it (including me). The opening at the base is the exact size of the air metering body intake opening, and the height of the filter is perfect, too. You do need to cut or grind a small half-moon in in the rubber down at the bottom (the widest part of the filter) so that it is not pressed up tight against the idle mixture adjustment plunger. It is a little bit tricky putting the filter in place if you do not want to wrinkle it up. One person on here lowered his engine slightly, but I figured out how to angle it in there so that I could install it without damaging/crushing/wrinkling any of the pleats.
http://www.amazon.com/gp/product/B000NKCIR0/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1 Here's how it looks installed, and I think you can make out what I mean by cutting a spot for the metering plunger in the first picture (if not, I can try to take a better one). ![]()
Hey Ronnie...that looks like just the "filter". OP probably need the filter housing to attach it to the intake opening? No?
Rahl |
OK...now I see hose clamp!
Rahl |
How do you vent the crank case in this set up? Atmosphere? I thought the original crank case vent went into the stock air filter housing.
Thanks Wi |
Banned
Rahl, that K&N is basically the exact same thing as the Fabspeed/BMC but just shaped differently (one piece filters/rubber housings), and each are secured by a large hose clamp (like you noticed).
Will, yes vent to atmosphere. In factory trim, the crankcase actually vents to an oil & vapor separator and then vents from there to the air filter housing by way of a "y" hose that also joins with the oil tank vent. So the "best" thing to do with a filter like this is add a catch bottle and put the hose that normally goes to the factory air cleaner there, and then run a hose from the catch bottle's vent and out and under the car by way of the gap that is near the right shock tower (where the factory a/c hoses go). That way, the fumes are not vented into the engine bay where they are blown all over the place by the fan - would obviously suck big time (like Paul) if you ran the heat with it vented like that. Last edited by Ronnie's.930; 01-14-2015 at 09:53 PM.. |
I have the same one. IIRC it was less than $40 delivered from Amazon.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Crotchety Old Bastard
$300 for an air filter is just plain stupid.
The cone filter is $40 and works better as it takes up less space.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Banned
!!! unless you like coked on bongresin? ??? NEVER AGAIN: CATCHCAN FTMFW: ![]() srsly. Say, Will - been awhile since you've posted any updates to yer reconstruction thar... hope things are goin smoothylylike for ya? Spring's comin! 8-) |
Even cheaper K&N including hose manifold for all vents discharging in the middle of the top cover and no interfrences...
Hey Paul, where did u get that catch can? I need one for the 356 case vent.
Banned
the classifieds here, Miguel - sorry
while I run the K&N you posted, I'm looking into the one Ronknees posted - it (at least looks like) it has more surface area? anyone know? |
[QUOTE=Ronnie's.930;8440356]This fits perfectly and many on this forum use it (including me). The opening at the base is the exact size of the air metering body intake opening, and the height of the filter is perfect, too. You do need to cut or grind a small half-moon in in the rubber down at the bottom (the widest part of the filter) so that it is not pressed up tight against the idle mixture adjustment plunger. It is a little bit tricky putting the filter in place if you do not want to wrinkle it up. One person on here lowered his engine slightly, but I figured out how to angle it in there so that I could install it without damaging/crushing/wrinkling any of the pleats.
Looks nice, tks.
tks, do you have a part number for this?
Hey Paul!
I got a rear clip and driver's fender (FINALLY) from DC Automotive. The doner is a Hurricane Sandy loss. The car goes to the shop next week for a little TLC. I have two seasons of driving to make up for and looking forward to it. Thanks for asking. Will |
The filter is a K&N # E-3270. It fits right on the throtle body - same diameter.
The carrier/holder is a standard product you can get at any parts store. Mine was chromed, I painted it black (outside only). You only use the top half, drilled two holes to use the OEM hold down bolts. You'll have to notch the bottom lip of the filter to accomodate for the mix adjusting flex bolt, which is located about 2 o'clock of the opening, if you know what I mean - no biggy here. Off the shelf stuff = a peculiar sound and clearer engine bay. |
Banned
that is really great to hear, Will - on all accounts 8-)
hope it progresses along for you to your expectation - keep us posted w/ some pics jah? if nothing more - I use your case as significant motivation / constant reminder of what NOT TO DO w/ my car! heh heh... |
Paul,
I like to think of it as the car now has self inflicted provenance on a historic race track. |
glad I saw this thread. wanted to know where to find these alternate air cleaners.
I have stripped out the entire AC. not sure if the catch can would fit where the AC compressor was, but also considering a full bay Turbocraft IC. so replacing the stock air cleaner body is where I think I'll end up to have space for mounting the oil catch can.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
