-   -   Input shaft seal picture (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/861878-input-shaft-seal-picture.html)
quattrorunner 04-22-2015 02:55 PM
Thanks guys, I'm going to try and yank that tube out tonight.
I'm not sure why I didn't figure out that that tobe came out.
It's not going to be easy by the way it looks.
Ronnie's.930 04-22-2015 02:56 PM
Originally Posted by quattrorunner (Post 8589766)
Thanks guys, I'm going to try and yank my tube out tonight.
:eek: !!!!!!
Jeff NJ 04-22-2015 03:06 PM
Originally Posted by boosted79 (Post 8589759)
Looking at it again the o ring just seals between the seal tube and case so you shouldn't have to do anything unless you want to change that inner seal.
And this would be why I had not come across this seal as something to replace while the motor/trans is out.
boosted79 04-22-2015 03:09 PM
If it isn't leaking I might let a sleeping dog lie. Might get into more problems pulling that tube than it's worth. Put oil in the trans end and set the box on the floor on the bell. If no oil runs out the seal tube I wouldn't touch it. Polish the splines and bolt on the guide tube and you're good to go.
quattrorunner 04-22-2015 03:11 PM
Good idea
Ronnie's.930 04-22-2015 03:12 PM
^^^ Excellent advice right there!
quattrorunner 04-23-2015 12:25 PM
It held the oil in at an extreme angle indicating it had a good seal. So.....guess I didn't Need to worry about it.
MikeD930 04-23-2015 03:22 PM
Then you should be good to go!
Ronnie's.930 04-23-2015 03:25 PM
The same can't be said for Paul - too errr, worn to "hold" anything in!!!
PS - great news about the seal - I know you're happy not to have to open the gearbox up again!
Tom F2 02-25-2016 11:00 AM
Am I the only one who found it impossible to pull out the tube with the differential carrier and ring gear in place? I had not trouble breaking the tube loose, and sliding it part way out. My 930/33 (1977) has limited slip and an Andial 8:39 final drive. Would either of those two prevented me from removing the tube?
All of this sticking shafts into tubes is bound to draw a few jokes. I'm ready!
Ronnie's.930 02-25-2016 05:33 PM
Maybe Brandon, the OP, will chime in since he has shown himself to be quite skilled with all things shaft, tube and hole related! :eek:
