Alexm930's Avatar
New Rear Valance Install
Finally ordered a new rear valance, thought to be NLA for the 930, but Jim Ellis had them. i have seen videos on youtube of how to cut the right side but was unsatisfied with just cutting the whole right side off due to it being symmetrically uneven. So I cardboard template & used a dremel for this look.
Then some rattle can GP White & clearcoat
Finished look
Speedlimits are for the guidance of wise-men & the obedience of FOOLS!
Old 06-08-2015, 10:05 AM
Alex,
Nice job on the cut out.
Is your 930 a European model or did you convert the rear bumpers? If you did the conversion I would be interested in knowing what it takes as far as playing around and modifications needed.
Thanks,
Edwin
Old 06-08-2015, 10:13 AM
Alexm930's Avatar
Originally Posted by EdwinL View Post
Alex,
Thanks,
Edwin
Yes Edwin, its a ROW German that I brought over 2 years ago. Completely non Federalized.
Old 06-08-2015, 10:33 AM
Very nice!
Old 06-09-2015, 08:32 AM
can you tell me if there is a folded edge/ bent edge in the bottom of the valance?
looks good
Old 06-09-2015, 08:59 AM
porche's Avatar
looks good
Formed edge, not rolled.
1979 Indishrot 930, Rudolph
"Dad, buy it! Real race cars don't have sunroofs."
Old 06-09-2015, 09:33 AM
wjfk32's Avatar
Well done
Old 06-09-2015, 12:37 PM
Tinkering Pays!!
mooney265's Avatar
Alex, I used to have a Borla. I see it appears to be a bit "unlevel" from left to right. Mine too was originally like this, and I was able to bend the muffler by carefully and slowly picking up on the driver's side [while mounted]. This caused the DS to lift a bit and the PS to drop a bit.
Disclaimer: do this at your own risk! Or, leave it...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 06-09-2015, 03:35 PM
Alexm930's Avatar
Formed.
Old 06-10-2015, 05:11 AM
Alexm930's Avatar
If & when I attempt an adjustment of driver side I will heat the pipes & then try what you suggest. To do it unheated would just seem too risky of causing some damage at turbo mounting flange.
Old 06-10-2015, 05:14 AM
