-   -   Where to get an adapter for engine oil inlet/964 filter mod? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/871425-where-get-adapter-engine-oil-inlet-964-filter-mod.html)
smurfbus 06-20-2015 03:38 AM
smartracing has gone MIA. All the articles tell to get a smartracing adapter.
Is there a stock part that could be used from a 964 or 993 or do I need some special adapter? I found a 993 engine to 911 adapter on pelicanshop but that one looked a bit deep on the flange.
http://forums.pelicanparts.com/uploa...1434796255.jpg
Jbracing has a adapter with AN fitting
http://forums.pelicanparts.com/uploa...1434796333.jpg
but are there any that connect straight to the s-line?
http://forums.pelicanparts.com/uploa...1434796369.jpg
mreid 06-20-2015 06:30 AM
The Patrick one in your picture is what I'm using. Works great on the 3.6 in my 74 911.
mreid 06-20-2015 12:38 PM
To be clear, here is my 95 3.6 with the adapter above. It is for the 993 engine.
http://forums.pelicanparts.com/uploa...1434828968.jpg
Here is my 91 3.6 with the correct adapter for the 964 engine.
http://forums.pelicanparts.com/uploa...1434829031.jpg
smurfbus 06-20-2015 02:06 PM
It looks like the 930 case has different style oil inlet and either of the 964 or 993 tubes would fit correctly? Its only about 4mm deep for a oring
http://forums.pelicanparts.com/uploa...1434834164.jpg
Pat RUFBTR 06-20-2015 03:00 PM
On my 930 Ruf BTR I put that one. ;)
http://forums.pelicanparts.com/uploa...1434837564.jpg
WinRice 06-20-2015 04:08 PM
I have the 15 degree console and have been looking for the same thing. Should have bought it before Smart Racing shutdown.
My only thoughts are to get the Patrick or JB -16 AN adapter and have a local race shop flare and bead a piece of tubing. Most AN flare tools don't go up that high, and the -16 tool is expensive.
mreid 06-20-2015 05:18 PM
Your case was designed for an oil cooler. Why are you using the 993 filter console? An oil cooler would bolt right on.
