More CNC Fun - Fuel Rails
As I'm collecting parts for my EFI project, I decided to make some fuel rails.
I know that the stock rails are fine....I'm just having fun. The raw rails are -8 and will use a -8 port fitting for -6 lines. In the end, I determined that I need to try again as the injectors were much too tight in the bore and I had a hell of a time with the stainless steel brackets. I have a bunch of laser cutting that I need done, so, I might just add a few brackets to the job. ![]() ![]()
-Todd 1987 911 Turbo, Marine Blue, GT35R, BB Headers, Tial, Andial IC |
Very clean looking, good job.
75 930, 76 930, 83 SC EFI turbo |
Those look great.
You should make another set and send them to me for long term testing! |
Chain fence eating turbo
Thanks guys, I guess I'll have "several" brackets cut!
I do have a question...I milled the injector pocket with a 13.5mm end mill and can only get 1/2 of the injectors to go into the bore. Yes, there is a chamfer. Is it possible that the old injector seals just aren't compressing enough and keeping the injector from inserting?
I think the OEM fuel rail injector pockets are tapered, not square.
Since I was going to need injectors anyway, I ordered some 60# Deka and they were a perfect fit. I guess the old O-rings were just not soft enough.
To those that wanted to test them....I made an extra pair. Beware that these were designed for the Carrera intake! ![]()
PM sent.
I'm up for a set if you end up producing these.
1973 Porsche 911 RS 1981 Porsche 931 Euro-Intercooled-GT 1984 Porsche 911 Euro Carrera widebody 1987 Porsche 924s Rallye Spec Instagram: @soyracer |
No air conditioning?
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
