shbop's Avatar
Understanding ignition switch & circuit
Thought I had an ignition switch issue when I first tried to shut off my 77' 930. The hesitation got me thinking I might have an ignition switch problem, but I soon learned that it's the nature of the beast. Would someone please explain what's going on here: why the delay? How do the components interact? where are they located? Thanks in advance!
Jon
Old 09-05-2015, 01:58 PM
mark houghton's Avatar
I first have to presume that the '77 is no different than my '87 with regards to the ignition shutoff delay relay. There is a silver rectangular "can" on the relay panel in the engine bay (left side). Said relay will keep the ignition (i.e., spark to the plugs) active for a second or two after you turn the ignition key to OFF. It serves to keep the engine running without the pumps, just on residual fuel pressure, to bleed down the fuel in the lines. The reason being to minimize or prevent leakage of fuel through the injectors after the engine has been shut down.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 09-05-2015, 05:38 PM
shbop's Avatar
Mark, thanks for the reply. Makes sense. When the can goes bad, do you know if it will prevent engine shut-off? I went out for a drive today, and when I returned, the motor would not shut down. I replaced the ignition switch, but no difference. Had me wondering if the time delay function was causing trouble.
Jon
Old 09-05-2015, 06:10 PM
Potentially it might behave like that. I just replaced mine few months ago. First symptom in my case was draining of battery. Not much, but after two weeks without driving the battery was empty.
When it got worse, the engine shut down took longer, but still manage to switch off. I would not be surprised that in some cases it just don't let stop at all.
New parts are now in black case and slightly larger, but fits in well.
Old 09-05-2015, 10:35 PM
Banned
My ignition shutoff delay has not worked in at least 8 years (no delay at all) - I guess it would be a good idea to replace the box (they're really pricey though, right?)?
Old 09-05-2015, 11:37 PM
shbop's Avatar
So, does your motor shut down right away?
Jon
Old 09-06-2015, 05:46 AM
Banned
Yes, shuts down right away like any "normal" car (no delay at all when the key is turned to "off"). The delay has never worked since I have owned the car (about 8 years or so) - I knew it was supposed to have a delay (and the reason for it), and that the silver box on the rear fuse/relay panel was the controller/relay for that function, but have never done anything about it.
Old 09-06-2015, 01:36 PM
shbop's Avatar
Thanks Ronnie. Lately it feels like my old days with Triumph, BSA, and Norton. Lucas electrics, (aka), "the prince of darkness."
Jon
Old 09-06-2015, 03:42 PM
Alan L's Avatar
anohter fuel head query
Disregard - trying to do new posting.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 09-06-2015, 03:48 PM
I used to ride vintage Triumphs. I'll never forget replacing my headlight. Right on the box
it says "Lucas Prince of darkness"
Not real confidence inspiring.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 09-06-2015, 06:45 PM
