3 restos WIP = psycho
kenikh's Avatar
Issues: Interface between the BPV and intercooler
Something isn't right between my BPV housing and intercooler. The IC bottoms out in the housing, but there's a healthy gap. Compounding this, the o-ring feels like it isn't creating a tight seal. What's the deal?
I'm going to smoke test the system tomorrow and expect this to be the area that is puking boost. Pics:
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-17-2015, 06:05 PM
Banned
Kenik, for one thing, you are missing the second o'ring - one goes on the intercooler spout and into the secondary intake manifold's opening (not like that, all you pervs!), and another goes in the gap you see in pictures and gets squished between intercooler and manifold..
I'll take a picture late tonight when I get back home, if that will help.
Old 10-17-2015, 06:26 PM
kenikh's Avatar
This?
930-110-379-00-M136
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-17-2015, 06:41 PM
Banned
No, regular o'ring - same as the one that is on the intercooler spout.
That pictured is a vibration damper that goes between the compressor up pipe and the intercooler.
Old 10-17-2015, 06:45 PM
kenikh's Avatar
I guess a pic will help. The red o-ring?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-17-2015, 07:07 PM
Preferred pronoun:Maestro
Norm K's Avatar
Here's mine ...
[IMG][/IMG]
When in doubt, use overwhelming force.
Old 10-17-2015, 07:26 PM
Norm K's Avatar
^^^ There's also an inner seal about an inch down.
Old 10-17-2015, 07:34 PM
kenikh's Avatar
Inner seal is there. Thanks for the pic.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-17-2015, 07:39 PM
Banned
Kenik, maybe you've already located these, butt if not, here is the correct o'ring.
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
Page 65, item #2 of the PET - note that 3 are required even for stock intercoolers (1 on the entrance spout and 2 on the exit). Same size as as your 1979, btw - never changed.
http://www.porsche.com/all/media/pdf/originalparts/usa/911_USA_87_89_KATALOG.pdf
Old 10-18-2015, 12:15 AM
Innocent Bystander
I have similar alignment problems when the up-pipe from the turbo becomes rotated slightly from it's correct position. On mine, repositioning the up-pipe brings everything back in alignment. My car is stock but I think that would still apply. Worth a look regardless.
Old 10-18-2015, 12:02 PM
16Volt's Avatar
Here is how my B&B mounts.
IMG_6158 by Shannon, on Flickr
IMG_6157 by Shannon, on Flickr
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 10-18-2015, 12:21 PM
mark houghton's Avatar
Surely, the inner seal is what's critical since it sits in a machined groove with close tolerances to seal when the IC is mounted. I've often wondered about the outer seal's effectiveness, but it sure can't hurt.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 10-18-2015, 12:50 PM
Banned
Part of its purpose, buttofcourse, is to help position the intercooler correctly, Mark.
Old 10-18-2015, 02:37 PM
kenikh's Avatar
Originally Posted by kenikh View Post
This?
930-110-379-00-M136
The PET is wrong? It shows this as a seal between the IC and BPV. Page 65 from the link above.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-18-2015, 07:20 PM
Banned
Kenik, on page 65, what you have pictured above is item #3 - seal between intercooler and up pipe (same part number you typed, too). It doesn't do any sealing, however - just a vibration damper and to prevent metal chaffing between the intercooler and up pipe.
I will teach you, bro!!!
PS - the BPV spout is not pictured in the PET drawing on page 65 (only the up pipe spout), but note that is says quantity of 3 for item #2 - that's because they are the same sized o'rings on the intercooler and 3 are needed.
Old 10-18-2015, 07:27 PM
kenikh's Avatar
Derp on me
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-18-2015, 07:37 PM
Norm K's Avatar
Derp on me
Careful, Ronnie's likely to interpret "derp" as only he can and volunteer to do it.
Old 10-18-2015, 07:43 PM
Banned
Im'ma "derp" you, Norm - two times!
Old 10-18-2015, 07:44 PM
kenikh's Avatar
Who needs OEM o-rings when you have mil spec in any size under the sun?
McMaster-Carr
I am considering purchasing some oversized rings of various materials to see if I can't get a better than OEM seal at the neck interface point. Smoke test first, though.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-18-2015, 09:49 PM
gumba's Avatar
Do the double 0 rings also apply to the 964 i/c?
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 10-18-2015, 10:27 PM
