Gawd-cammit - Need cams, like now.
So I appear to be moving through my rebuild faster than I budgeted and planned on. The net result (other than having to flake out on Jacob's gorgeous Fikses) is that I need cams....like now.
If you have looked for new billet cams in the last few months you will know that there are basically none to be had in the US save for some extreme setups. I wanted to wait until there was more billet stock available but I dont have a choice now so I need to decide from the 3 below options. Here is my setup - 3.3 K29/K27 hybrid B&B shortneck B&B headers RarlyL8 Hooligan Twin Plug/XDI2 ignition Knock Sensing 1bar spring in a tial WG dual divertors/no mid manifold BL WUR with RPM sensor CIS I am looking for midrange punch, i dont wind the car out all that often and am looking for 'drop a gear, blow your mind' speed'. The car was running a set of Elgin regrinds which ate themselves. It made boost down low and felt great. Options - 1. Send out a set of SCs to Dougherty for regrind to DC15s/pump drive attachment 2. Send out a set of SCs to Web for regrind/pump drive attachment 3. Send out current Elgins back to Elgin for repair Thoughts? IMG_9895.jpg by Shannon, on Flickr
- 86 Porsche 930 - Mr.Hyde - 86 BMW 635CSi - Dr.Jeykell - 2006 Infiniti M45 Sport https://medium.com/@crashingdoor |
I believe Chris @ TurboKraft has a set of Edelweiss in stock, give him a call.
930T Owner
Doesn't take long to start modding, does it...
Happy modding!
Hams930T 2017 Turbo S |
Have you thought about getting some oem 964 cams and adding the scavenge drive? Hard to beat oem quality, and they should be more than enough cam. That's my plan anyways.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC '12 Gallardo LP-570-4 Performante Ducati 748R |
beancounter
I have a used set of Elgin "Super SC" grind cams that came out of my race car. Would need to add the provision for oil pump drive on the driver side cam, but they are appropriate for CIS cars and marketed as a "hot" cam suitable for the CIS equipped 911 SC.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 Last edited by jwasbury; 12-03-2015 at 01:51 PM.. |
Dumb question - when people put in 'SC' cams are they just stock SC cams with the oil pump drive put on? I have heard the team SC212s and SC330s thrown around like the are SCs but reground and have the pump drive put on.
Edelweiss camshafts are machined by the same little company who cut 911 air-cooled cams for Porsche Motorsport. Top equipment, top tech.
In the first car we used Edelweiss cams, overall output was considerably better than expected. Happy with them, ordered in 3 different sets: * Mild -- more than SC or 964, available for sale, work with CIS * Medium -- more than GT2 cams, going into a Pelican's EFI 930 * Hot -- going into a big bad ITB Twin Turbo we are building They are $1,995/pair. Same price Edelweiss sells them for, with $100 freight included (FedEx cost more than that). Less than new factory camshafts, more than most US aftermarket camshafts.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
And here is what came out of my car -
IMG_9900.jpg by Shannon, on Flickr IMG_9896.jpg by Shannon, on Flickr
964 cams are better on a CIS engine when you have
more displacement more compression porting or, all of the above. From our discussion of your modifications and intended use, SC cams -- or the slightly improved Elgin/Dougherty variants -- are better for your application.
Yeah, I am stock displacement, stock comp and no porting.
Just wanted to make sure I wasnt going totally insane. I wish the Porsche cam world was like the VW cam world as in there is a relatively standard nomenclature....
Per Dirk at Edelweiss, this mild cam will still idle at or below 1,000rpm, torque onset is earlier than the little SC cams, with better upper rpm power than 964.
beancounter
Buy my wheels, and I'll throw my cams in the deal
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Wondering why new billets are so scarce, just not enough demand?
The pitting in the cam lobes looks like not enough oil was being sprayed at the cams by the cam spray bars so some of them may be clogged. It's also possible motor oil with low levels of ZDDP was used for a while and caused more wear on the cam lobes and rocker arms. There are 3 cam spray bar holes per cylinder or 9 in each cam spray bar and you have to remove the cam towers to clean them out and confirm they are clear and not clogged or partially clogged. With them on the motor and in the car you can only see one spray bar hole per cylinder - the one that sprays oil straight up so it splashes off the back side of the intake valve rocker cover to lubricate and cool the valve train parts that may not be reached by the direct stream of oil being sprayed by the other cam spray bar holes. I've been through this stuff and it $ucks.. good luck with making it all good. |
That's why on any build we do as final check before the cam towers etc get locked down, we'll load the passage with oil and then pressurize it looking for nice spray x that 9.. occasionally you find one that doesn't spray as clean as the rest.. time to rip-it apart and re-clean!
RGruppe #180 So many cars.. so little time!! |
Banned
I've got a pr of sc cams that I'll sell. Just need pump drive added. (150. Is what I was quoted) and I'll sell very fairly priced. Thx. Mark
Who quoted $150 to add a pump drive ?
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Banned
Brian bodart
Kartoffelkopf
![]() But as said, I defer to Chris with his advice, especially if running CIS. ETA: We're still working on drivability mapping - 1 day done but still some way to go until I'm happy with the transitioning between maps, so I can't really give you a true idea of how the cam drives...its very wet/greasy on the roads in the UK and the chassis is all over the place in terms of geo....but even on low boost setting (0.7bar) it's "interesting" [British understatement mode=off]...or maybe I'm just a wuss....
1993 (MY92) 964 Turbo 3.3 - Horizon Blue - Follow my 964 Turbo project here... http://forums.pelicanparts.com/911-engine-rebuilding-forum/626572-964-3-3-turbo-efi-conversion-using-syvecs-life-racing-engine-management.html On Instagram (along with other stuff) as @spenny_.b #spennybengineproject Last edited by Spenny_b; 12-06-2015 at 03:01 PM.. |
