Exhaust tip refinishing
About to reinstall the original muffler back onto an 86 930
The tip appears to have been originally black , but now the finish has worn off in areas
Is there a preferred method of refinishing the tip Anyone have any experience ?
Thanks in advance for any input
Old 12-21-2015, 11:49 PM
xbmwguy's Avatar
Semi gloss BBQ paint. Avail at home depot
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp
Old 12-22-2015, 04:21 AM
You have to clean and sand them with 320 grit sandpaper first so the paint will stick and last better.
Spray on a light tack coat of the paint, let it dry around 5 minutes, and then spray on a couple wet coats around 10 to 20 minutes apart.
The directions on the can may be better.
Some cans of high temp puff can paint are much better than others.
The best I know of is: Bill Hirsch Space Age Black Hi Temp Paint 13 oz Spray USA BH Saba | eBay
Or you could remove them and have them ceramic coated.
Old 12-22-2015, 08:26 AM
