-   -   Good Connection for Pressure Sensor??? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/898061-good-connection-pressure-sensor.html)
930/66 01-10-2016 08:35 AM
Hello everybody
I don`t need longer the connection for controlling the vacuum unit of the distributor.
It is a good vacuum / boost source? The hole (after the trottle plate) is really small.
Cheers Thomas
http://forums.pelicanparts.com/uploa...1452443676.jpg
http://forums.pelicanparts.com/uploa...1452443702.jpg
proffighter 01-11-2016 02:27 PM
Hi Thomas. I guess no, because if I remember correct, it's not below the throttle plate when closed, so you will not get correct vacuum values. T-Connector on the other side is lower, therefore way better for your needs.
Gruess Roland
930/66 01-12-2016 10:36 AM
Hi Roland
there gives three connectors:
1 T-Connector (with a normal hole below the throttle plate)
1 Connector with a blue hose (with a thin hole below the throttle plate)
1 Connecor with a red hose (with a thin hole before the throttle plate)
The thin hole is about 1mm, the question is can that work?
930/66 01-16-2016 06:28 AM
I have changed the boost source to another connector and split it with a y-piece (boost sensor; cpi and ebc)
http://forums.pelicanparts.com/uploa...1452954495.jpg
http://forums.pelicanparts.com/uploa...1452954505.jpg
