930/66's Avatar
Good Connection for Pressure Sensor???
Hello everybody
I don`t need longer the connection for controlling the vacuum unit of the distributor.
It is a good vacuum / boost source? The hole (after the trottle plate) is really small.
Cheers Thomas
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods
Old 01-10-2016, 08:35 AM
proffighter's Avatar
Hi Thomas. I guess no, because if I remember correct, it's not below the throttle plate when closed, so you will not get correct vacuum values. T-Connector on the other side is lower, therefore way better for your needs.
Gruess Roland
Roland
930 Turbo '81 Too many modifications to list
Old 01-11-2016, 02:27 PM
930/66's Avatar
Hi Roland
there gives three connectors:
1 T-Connector (with a normal hole below the throttle plate)
1 Connector with a blue hose (with a thin hole below the throttle plate)
1 Connecor with a red hose (with a thin hole before the throttle plate)
The thin hole is about 1mm, the question is can that work?
Old 01-12-2016, 10:36 AM
930/66's Avatar
I have changed the boost source to another connector and split it with a y-piece (boost sensor; cpi and ebc)
Old 01-16-2016, 06:28 AM
