speednme1's Avatar
D-Zug brace install
Recevied a D-Zug cross strut brace...it's beefy..very well made. Justin was excellent to deal with. Future business is definetely going to happen.
This is the brace out of packaging.
Need to remove the front two 10mm fender bolts
Old 06-12-2012, 10:08 AM
speednme1's Avatar
Remove the strut to bolts(coilovers in my case)..and clean out the undercoating as best as possible and carefully(to make a nice flat surface). I did it with a hammer and chisel.
Installation is fairly easy..just take your time. Tighten inside bolt(closest bolt to the strut ) on the strut bracket first(onboth sides). Then proceed to tighten the rest of the bolts on the strut tower and corner brackets . The lastly tighten strut towers. this is what it should look like.
one more..
Thank again Justin(and th rest of the D-Zug crew)
Rey
Old 06-12-2012, 10:25 AM
That looks killer. let us know your impressions of it out in the real world.
Ken
1986 930 2016 R1200RS
Old 06-12-2012, 11:26 AM
Pure Awesomeness
szyzygy's Avatar
Noob question
What do these things do?
1977 Porsche 911
Old 06-12-2012, 11:42 AM
speednme1's Avatar
Sure....once I get my seats back...
Old 06-12-2012, 11:45 AM
speednme1's Avatar
Originally Posted by szyzygy View Post
Noob question
That answer I will leave up to the D-Zug guys...hopefully they will chime in.
Old 06-12-2012, 11:46 AM
Happiest when Tinkering
gsmith660's Avatar
The brace ties the 2 shock towers together so they cant flex in or out with the help of the cross brace maintaining a set camber on your front tires. The X used in the 935's tied the front corners of the tub together with the cross brace to prevent any movement unlike other braces that tied one side of the cross brace to the sheet metal under the brace preventing any side to side movement but no fore and aft movement. It is most definitely on my to do list I have the weltmeister cross brace right now that did change the handling some this brace will be a big improvement.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 06-12-2012, 12:01 PM
Blackbird Pilot
Reaper930's Avatar
Here's the description of why we decided to engineer and pursue the product so much as the first of DZ's product line. A basic, "how it works" type explaination:
The X brace on the factory 934's and 935's was there to effectively stiffen and reduce the the understeer characteristics of the 911 platform. The 934 benifited from a much pointier nose and better front traction and stability under braking or hard cornering thus allowing higher speeds & an advantage on the track.
The 935 was a different story. As with the factory cars we cut the front end of my 935 off and welded in a strong steel bar between the two hood pins. This no doubt weakened the tub structure and required a brace to unite the front end again besides the single bar which supported the front mounted oil cooler.
The 935's were the lightest and the most cut up of all the chassis and at the time they had a significant issue with chassis flex due to a lack of cross stability when the rear of the car was hacked to pieces to fit the rear seat intercooler and cage. Those cages didn't "X" as most modern cages do now in the rear seat area.
The 935 was known as a "flexi-flyer" because of this, and the huge rubber the car was shod with - not to mention the power and effect that has on even a standard chassis.
Overall the "X" brace on the 934 & 935 was there to prevent the front half of the car from picking up an inside tire when one corner tried to raise up, the "X" brace would push it down or just resist the rise and put more rubber in contact with the track meaning higher cornering speeds and stability.
This was in addition to the standard type strut bar going between the towers which would prevent the towers from expanding or contracting on each other. The need for a bar down to the brake booster area or floor pan wasn't needed because of the stoutness of the tubing used and the fact that the additional protection from strut tower collapse or expansion simply wasn't an issue when the "X" brace was executed properly.
Sure the extra bar isn't going to hurt anything - but in a race car when every pound matters, each part has to pull its weight.
There is eveidence on a few factory cars where the "X" brace would actually bend towards the passenger side strut tower...these things weren't for looks but do their job quite well.
So after 3 months of development and testing we know they work from the speed differences during cornering & overall traction increase not to mention how tight they make the front of the car feel while piloting the K3. Justin behind the wheel of his 934 & Pete driving his 930 also noticed a SIGNIFICANT difference making the car (even a stock bodied 930) handle with a sharp nose allowing you to put your tires exactly where you want them to be.
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 06-12-2012, 03:30 PM
89 930.
Benny771's Avatar
DZ Chassis
Old 06-12-2012, 03:47 PM
Pure Awesomeness
szyzygy's Avatar
thanks for the explanation. looks like something I'd be interested in.
Also like the 5-point wheels you guys have on here, too.
Keep up the good work
1977 Porsche 911
Old 06-12-2012, 09:02 PM
juicersr's Avatar
Ray, thanks for the kudos bro, glad to help u make it happen! Great shotz and install pix. That brace looks phenomenal in your ride... love the yellow lenses BTW
Gabe pretty much summed things up nicely, but suffice to say that starting with the 934, the factory (or rather Norbert Singer, chief motorsports engineer) realized that the weak front end of the 911 would not be able to maintain suspension geometry under the significantly increased loads produced by 400+ hp. The relatively simple 'RSR' style strut-strut cross brace (similar to the one so many of us have installed in our 911/930's) just didn't cut it anymore for the 2.1 turbo RSR at the power levels it was making and the stress it was putting on an already intrisically weak front end.
934 brace
935 brace
Interestingly enough, (although it should come as no surprise) Alois Ruf choose to install 935 style braces in many of his Yellowbirds...
'79 930/934 replica
80 RSR-look(Now in Sicily)
914/6 2.7 (Projekt 908/3)
1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW
D-Zug Produkte/D-Zug.com
Old 06-13-2012, 05:37 AM
These still available anywhere?
1988 930 Blk/Blk - Not Stock
Old 01-06-2016, 01:36 PM
Banned
look up user pkracer21 (Pete) here or juicersr (Justin) on the 911 forum and they'll hook you up
bar is awesome, and the benefit to dynamics is *phenomenal*
Old 01-06-2016, 01:46 PM
nice bit of kit!!!!!!
Old 01-06-2016, 02:32 PM
VZ935's Avatar
Send a message via AIM to VZ935
That's photo is after I sold that 935 to a friend back in 2001. I have since owned it two more times buying it back the last time in 2011. I think I made that front cross bar after the car took a little damage at Road Atlanta in 2000 or 2001 duplicating it off one of my other factory 935's
935 brace
A bunch of old race cars
Old 01-11-2016, 03:09 PM
That looks awesome Rey.
I used dry ice to remove my undercoating and it just peeled back without having to get the muscle out.
Old 01-12-2016, 04:25 AM
SweetWaterSurprise's Avatar
Have the same brace, just looks great.
Old 01-12-2016, 05:28 AM
