RPM fluctuating at idle
The RPMs in my '79 930 are fluctuating between 800 and 1200 while idling. It constantly fluctuates, revving up to 1200 from 800 over and over.
Any idea what the problem could be?
Old 01-22-2016, 08:11 AM
T77911S's Avatar
too rich
check for 12v at the warm up reg (WUR) would be a first check
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 01-22-2016, 11:42 AM
yup, too rich.
All mechanical air flow meter fuel injection systems - sensor plate like CIS has or flapper door controlled like L-jetronic has will do that when they are too rich.
Old 01-22-2016, 01:20 PM
mark houghton's Avatar
As suggested, do check that you have power to the WUR, to make sure it's warming up and leaning out as it should. Also, if you have the gauge setup, you should check system and control fuel pressures (cold and hot) against specifications. This is particularly warranted if this problem suddenly appeared.
Short term, you can adjust your mixture slightly leaner at the mixture control point on the fuel head. 3mm allen wrench, push down until it engages, and turn counter clockwise just a degree at a time.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 01-22-2016, 03:04 PM
Related question... I realize "surging" idle RPM as the OP described is a symptom of rich fuel mixture. But how, if at all, would the presence of an A/C compressor impact how one sets idle and fuel mixture on a CIS car like our 930s? Obviously if the compressor is running, you have a small extra load on the engine at idle.
Lee
'72 911 ST Tribute (built by Scott Longballa) - Signal Yellow
'74 911 Carrera Targa (2.7 MFI - RoW) - Silver / Polaroid Stripes
'77 930 - Minerva Blue
'97 993 Turbo S - Ocean Blue Metallic
'13 981 Boxster (BGB 3.8L 991S conversion) - Racing Yellow
Old 01-24-2016, 05:58 AM
