clutch tool
What are you guys using for a clutch alignment tool? I don't see one for the 930 on pelican.
Thanks.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 01-25-2016, 06:33 AM
I used a generic tool, always had good luck with it.
Gearwrench 2420D Clutch Aligning Set | Automotive | Toolfetch
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 01-25-2016, 06:38 AM
proffighter's Avatar
Look for this:
Here:
1981 Porsche 911 SC Coupe - Clutch & Flywheel - Page 2
Check measurements, but I think 930 is similar...
Roland
930 Turbo '81 Too many modifications to list
Old 02-01-2016, 03:32 PM
IMR-Merlin's Avatar
I made on with a long socket and a bunch of electrical tape. Worked perfectly
82 twin plugged, EFI, G50 930, RSR suspension (soon to be) GT35R...
Old 02-01-2016, 03:52 PM
Banned
If Paul sees the thread title, he'll assume it is a command and commence clutching (as usual)!!!
Old 02-01-2016, 03:55 PM
totle's Avatar
our host has it
Clutch Alignment Tool PELTOLCA3 - Clutch Masters - PEL-TOL-CA3 | Pelican Parts
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 02-02-2016, 01:32 AM
I have one like proffighters
it says ford on it
you are welcome to borrow
I used it to install a rsr LW & clutch on mine
central austin
stefan
Old 02-02-2016, 05:46 AM
Thanks Stephan. I may have a ford tool. I will have to look. If not I may take you up on it.
John
Old 02-02-2016, 07:53 AM
