Is very busy
There's a small toggle switch just outside of the footwell on my 930 Slant. I don't know what it's for or what it's connected to, and it's always been in the "up" postion. Today it was midway between up and down, and I guess that's when I started having the boost problem. Is this toggle switch connected to my boost controller or something else?
Here's a photo. Sorry it's dark, I couldn't get enough light in the photo, and I put it back to the "up" position: ![]() Thanks,
Jason 1987 930 Slantnose Cabriolet, 545 hp, Guards Red- Weekend cruiser 1986 944 Turbo (951), 350+hp, Guards Red- Track car 2005 Toyota Tundra SR5 Double Cab 4x4, stock 282 hp, Silver- Daily driver |
That's the switch to the p*ssy magnet. They made them extra strong in '87. The parts are NLA. Use judiciously.
Is very busy
hahahahahahahahhaah
1984 930 3.3 Turbo 2004 BMW X5 4.4i 1983 BMW 320i 1993 Vaz 21063 |
Banned
Is very busy
That's funny, but I really want to know what that switch is for
Well it isn't factory so you will need to pull the cover loose and trace the wires.
Tinkering Pays!!
You got aftermarket Amp or Alarm? It's definitely not stock...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR. |
seriously its probably soime aftermarket alarm system or something.
Is very busy
My car does have an aftermarket alarm system, but I tried moving the switch with the key in the ignition and nothing happens.
My slant has a switch like that too. I've been afraid to touch it for the last 8 years. Lemme know what you find out!!!
Is very busy
Both, actually. But it doesn't seem to affect the alarm system. It's been in the "up" position since I bought the car, and today it was halfway down, which was also when my boost problem started, which I wrote in a separate thread if you want to read it.
83 911 Production Cab #10
After Burner Option 1215 offered in 87. Use with caution.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
That's the take off switch, it only engages at 350MPH so don't worry...
Now seriously, if you follow those purple w/green connector wires might take you there because those wires are not OEM either. |
Brando
Flip it the rest of the way and see what happens next. Maybe it's a on off for a ebc.
Turbo powa! 1977 911s. it's cool |
Banned
ejection seat
which is enTIRELY different than ejaculation seat or erection seat |
High beam switch. Old school Chevrolet style.
Is very busy
I'm not so sure about that, because I just turned my lights on, moved the switch around, and nothing happened.
930T Owner
I'm going to guess on a valet switch or something tied to your alarm. As ohers have stated, the only way you will ever know is to pull the kick panel out and take a look at where the wires go. That isn't an oem switch so not much help on it's purpose. Investigative work will be required here.
Chris.
Hams930T 2017 Turbo S |
I have one & have believed it to be the power antenna. It has a fuse missing under that panel & have never messed with it. Just a thought.
88' 930 03 Tacoma, 04 Duramax, 06 R350 Benz If you are traveling at the speed of light & turn on your headlights, does anything happen? |
