Certified User
billjam's Avatar
Camshaft welding by Tighe Cams - don't ...
As part of the "while I'm in there" story, which is closely linked to the "slippery slope" story, I decided to get my turbo cams built up and reground to SC profile.
A company called Ivan Tighe Engineering in Brisbane Australia (also trading as Tighe Cams on the net) was recommended by several acquaintances so I duly sent my cams off more than seven weeks ago for what was promised as a two week turnaround job.
Apart from the continual promises of "they'll be ready to ship tomorrow or the day after", you've got to question the guy's workmanship.
They arrived home today - pictures tell a thousand words ...
Almost all lobes have transverse cracks and pitting. Impressive eh!
To make matters worse, they were sent back with a grey paint-like finish on all lobes which hid what was lying below. It washed off easily with petrol and felt slippery so it might have been some kind of assembly lube. I almost decided to leave it in place!
There is no way this guy could not have seen these cracks and pits before he painted them.
Tomorrow, we start negotiations about where we go from here.
Regardless, it looks like I'm in the market for some real SC cams.
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 10-29-2008, 05:21 AM
Certified User
billjam's Avatar
I forgot one ...
Bill
2024 Macan S
Old 10-29-2008, 05:55 AM
sudo apt-get purge 930
equality72521's Avatar
WOW, that's horrible. Good luck to you. I've got a set of SC cams I'd sell but they will require reworking.
--clutch-monkey
Old 10-29-2008, 06:06 AM
resident samsquamch
sand_man's Avatar
mmmm, that's nasty! Especially that last picture with the void. FWIW, I got my SCs from Imagine Auto.
-jeff
Old 10-29-2008, 06:14 AM
David's Avatar
From the Tighe website:
" With many years of knowledge and experience along with new technologies Ivan Tighe Engineering has not been out classed by new competitors in the industry. We at Ivan Tighe Engineering firmly believe that our quality products, service and manufacturing are second to none in our industry."
Old 10-29-2008, 07:01 AM
resident samsquamch
sand_man's Avatar
"We at Tighe Engineering would like to welcome our new master welder":
-jeff
Old 10-29-2008, 07:10 AM
Me like track days
Craig 930 RS's Avatar
That is just flat and simple a **** job.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 10-29-2008, 12:25 PM
A930Rocket's Avatar
WOW! I take it they are going to reimburse you for a pair of screwed up cams!
How much is a new pair of SC cams? Are they readily available?
When I rebuilt my engine, I debated to go with re-ground cams because the 964 cams were out of stock and back ordered. I decided in the long run it would be better to wait for new.
Good luck!
Old 10-29-2008, 05:46 PM
juicersr's Avatar
LOL Jeff! Your stash of FAS (funny as $hit) pix is quite impressive.
Billjam, all you can really do in the face of such a blantant slipshod work is laugh to keep from punching someone. This a$$ clown of a company should refund your hard earned $$$$ with interest.
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 10-29-2008, 05:48 PM
Certified User
billjam's Avatar
I just received this reply to my email requesting refund or replacement cams. At least he didn't argue about it (mind you, I don't have the $$ yet!).
I just love the line about them being usable. These things must be akin to hand grenade pins.
Bill
2024 Macan S
Old 10-29-2008, 06:29 PM
A930Rocket's Avatar
Is he going to credit you for the work done only? What about your now useless cams?
Old 10-29-2008, 07:03 PM
Me like track days
"The cams are still usable, and we have used the cams in that condition before"
Uh, yeahh ....
Old 10-29-2008, 07:10 PM
Macht Schnell
les_garten's Avatar
Nice set of Grenades you have there...
That was assembly lube on the CAMS, basically a Moly Coating. I don't believe he'll pay you for your CAMS, he only really has to say send them to me and we'll re do them to avoid anything else legally. He also will know it is not worth the fuss you to go to court. You're screwed on those CAMs unfortunately. Thanx for the Heads-up on a Slip shod operation.
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Certified User
billjam's Avatar
Yep, he is refunding the work only. It's not just that I have to now find some SC cams and modify them (for pump drive), but my engine has sat half-assembled for more than a month waiting for this jerk.
They're not totally useless.
I'm thinking matching bedside lamp stands (won't she be impressed )
Bill
2024 Macan S
Old 10-29-2008, 07:19 PM
Me like track days
Have a use for 964 grind 930 cams that need one lobe minor repair?
Old 10-29-2008, 07:28 PM
Me like track days
This guy might have done a better job:
Old 10-29-2008, 07:33 PM
Macht Schnell
les_garten's Avatar
I've bought two sets of Regrinds from IA. I can "somewhat" recommend them. The problem is that the base of the base circle is ground all the way down to the CAM itself and makes the adjustment range on the Valve Lash adjuster kinda screwey like you almost are at the end of the adjustment.
When I do this again, I will just get billet Cams from Web-Cam, I've used them before for about 25 years, and they have really nice CAMs, and do a lot of Porsche grinds. If you have to come up with Donor CAMs and then regrind, Web-Cams would be about the same price or so.
http://www.webcamshafts.com/
Old 10-29-2008, 07:36 PM
Certified User
billjam's Avatar
I will look for a set of SC cams here (in Oz) first.
Thanks for the offer Les - maybe later if I can't find what I want.
Bill
2024 Macan S
Old 10-29-2008, 09:21 PM
dewolf's Avatar
Ring Mark Buik at Buik Motorwerks here in Adelaide. He runs the Adrad Carrera cup team. He will be able to find or recommend you to something or someone.
Old 10-30-2008, 12:28 AM
Wer bremst verliert
JohnJL's Avatar
Hi Biljam,
I'll send a PM...I have a spare set of SC cams in Sydney.
j
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-30-2008, 02:40 AM
