-   -   Programmable CDI Box - Classic Retrofit (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/907257-programmable-cdi-box-classic-retrofit.html)
Tonger 03-23-2016 05:21 AM
I was wondering if anyone had experience or insight whether this programmable CDI box would be worth pursuing. It seems like it would allow for a lot of flexibility with regard to controlling timing and detonation.
Classic Retrofit 911 CDI+
I think I may have some detonation on early boost initiation.
Alternatively, I can take the distributor out and have it checked....
Thanks!
kjchristopher 03-23-2016 09:12 PM
I'd try it if there was some way to vary the advance with load. (Best I can tell, it is only one advance curve, without adjustment for vacuum/boost)
Jonny H 05-08-2016 02:07 AM
Hi Tonger,
I missed this post. We currently have a few Turbos running our ignition. They show improvements in throttle response but we have not run one on a dyno yet.
We supply a locking collet that allows you to lock a Turbo/SC dizzy without dismantling or taking it out of the car. This will allow you to get a more accurate ignition map than with weights/springs.
Our £795 unit will do everything you need. Only difference to the £995 on is that it comes with a built in waterproof programming lead.
We are looking at integrating a MAP sensor but it is a way off yet. We also like the idea of controlling fuel pressure which would allow to provide a fuel curve of sorts.
Follow us on Facebook to keep in the loop.
http://www.facebook.com/ClassicRetrofit
