-   -   Brake improvements/upgrades? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/914155-brake-improvements-upgrades.html)
TurboKraft 05-31-2016 01:52 PM
Bosch Motorsport ABS system = amazing, they take a ton of info from you and deliver something almost perfectly calibrated out-of-the-box.
But be sitting down before you ask the price, last one I saw delivered was considerably over $10k.
Then add wheel speed sensors at all 4 corners, plumb it all, etc...
Good fluid
Good pads
Larger tire contact patch
Good suspension (maintain contact patch)
Last resort = bigger brakes
krasuskyp 05-31-2016 03:49 PM
Oh yeah good point on airflow. I'm ducted & blank-plate'd.
I'm on hooptiedubyo 18's, ala ballar.
flightlead404 06-01-2016 07:36 AM
So I need new tires. The Avons have on the rear are smoooooooth. Fronts still 75% tread lol (No, I'm not driving it like that)
I'm on stock 16" wheels and plan to stay that way for a while. I need to do a brake system flush anyway, so I'm looking at
Brembo LCF-600 fluid
Pagid Yellow RS29's
Toyo Proxes in the stock sizes
Brake ducts for the front
Should I look at other sizes for the tires? I'm lowered, bump steer kit installed, fender lips are not rolled and I won't do that
Craig 930 RS 06-01-2016 11:57 AM
IF...you NEED larger brakes: I have 993TT fronts and 944 Turbo FRONTS...on the rears. Bias valve as well - perfection.
