Brake improvements/upgrades?
So I did the Porsche Experience at HQ down by the airport the other day. Drove 911's and a Spyder with three different instructors. Damn, they looked like high school kids to me and their job is driving the crap out of Porsches......niiiiiice! Beats running an amusement park ride like I did!
Anyway, the brakes on these vehicles are phenomenal! I mean just blew me away. Especially the ceramics. What can I do to get my 930 to stop like that? |
I don't see the point with non-abs cars. I can press the pedal hard enough to lock up the tires on my 930, so other then fade resistance, how can it be improved?
Also, nearly everyone that tracks switches to steel rotors. Ceramics are way too expensive. |
Start with wheels and tires... put the same low profile rubber footprint (as the newer vehicles you drove) and quality tires on a lightweight wheel. Report back...
I put 928 S4 calipers up front and moved the original front calipers to the rear. Huge improvement! Much more modern/progressive feel compared the to normal wooden feel.
Sent from my iPhone using Tapatalk |
Rufrob - I have the same set up as you - S4 calipers on the front and Turbo calipers on the rear
Awesome braking! |
Anyone upgrading, can I have your old calipers? Upgrading an sc. Gimme a call to sell your old ones. 706-392-2580. Thx. Mark
Are 928 calipers a simple bolt on or does it require machining and custom mounting/parts?
Needs an adapter
Just my opinion, but I've never been disappointed with the on-track performance of my 930 brakes. Regarding ceramics, I was in the garage at Watkins Glen this past week and my neighbor had a new GT4 with ceramics and he was very disappointed with their on-track performance. He indicated that he would be switching back to steel rotors asap.
Regards, Dave |
I suspect the big difference is ABS vs not
Before you upgrade calipers, change your fluid to Brembo LCF-600 and put on Pagid Yellow RS29's... wear your seatbelt...
For those replacing original 930 calipers with 928 whatever or 993TT calpipers keep in mind good condition 930 calipers are now worth a lot more $$ than the others.
Agreed that stock 930 brakes that are properly set up (like any/all Rawknees joke) are more than excellent - even on-track.
Bleed and re-bleed with the right fluid and run good pads and there's no reason to "upgrade". Careful to not go too aggressive with pads, you'll chew yer rotors bigtime. I'm running Porterfield R4S which have proved to be a great combo of rotor-friendly / pad bite / warmup time / resistance to turning to goo (as does Rawknees within even the mere vicinity of dongs) / dust / price variables. I'll add that running more than the *shameful* 205 front tire section width aids in braking capacity STUPENDOUSLY! With my setup and 255s up front my braking performance is now utterly redonkular. |
They work well cold, something Pagid blacks do not. No squeal. Not bad for dust. |
I am not generally concerned about stopping power but fade resistance. I'm thinking about running my car out at COTA later this season once it cools off. The big straight after turn 11 will yield 150+ in my car with a shut-down left hander at the end. Given the length of the track I am honestly concerned I will overheat the stock brakes. I am running new OEM rotors on good condition calipers with SS lines and Carbotech XP10's. I have great bite but again my concern is pointing more towards to fade resistance on the big tracks where I am going to see significant speed. Thoughts? - Chris. |
You may be in luck. I think Bosch has came out with an after market abs system for racecars and re-equipping older cars without. I can't remember the details but it was featured in race car engineering mag a couple of years ago. If you are upgrading this may be the ticket for you to get the 930 closer to the modern pcars. |
| All times are GMT -8. The time now is 10:56 PM. |
