-   -   Is this a suitable engine temp sensor for MS/FrankenCIS? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/926682-suitable-engine-temp-sensor-ms-frankencis.html)
flightlead404 08-24-2016 08:51 AM
The simple VW bus head temp sensor suggested in an alternate thread is now made of unobtainium. I'm looking for an alternate way to sense engine temperature.
I was considering this. It is supported/suggested for MS installations.
Would this be a suitable sensor for this particular application? If not, suggestions for better alternatives?
I was considering mounting in the breather cover in place of the thermovalve. Either machining an adapter, or drilling/tapping as necessary to make it fit.
Would this be a suitable location? If not, suggestions for better alternatives?
dos531 08-24-2016 09:05 AM
I did exactly what you're saying with that sensor mounted in the breather cover. Works well for me.
flightlead404 08-24-2016 09:56 AM
Thanks Dos531.
Where did you pick up manifold pressure?
dos531 08-24-2016 10:16 AM
Originally Posted by flightlead404 (Post 9253441)
Thanks Dos531.
I believe I got it off the throttle body, ill have to double check.
flightlead404 08-24-2016 10:31 AM
The line that originally went to the thermo valve in the breather cover?
dos531 08-24-2016 01:18 PM
Not sure, that thermovalve hasnt been hooked up in a long time on my car.
