Is this a suitable engine temp sensor for MS/FrankenCIS?
The simple VW bus head temp sensor suggested in an alternate thread is now made of unobtainium. I'm looking for an alternate way to sense engine temperature.
I was considering this. It is supported/suggested for MS installations.
Would this be a suitable sensor for this particular application? If not, suggestions for better alternatives?
I was considering mounting in the breather cover in place of the thermovalve. Either machining an adapter, or drilling/tapping as necessary to make it fit.
Would this be a suitable location? If not, suggestions for better alternatives?
Old 08-24-2016, 08:51 AM
dos531's Avatar
I did exactly what you're saying with that sensor mounted in the breather cover. Works well for me.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 08-24-2016, 09:05 AM
Thanks Dos531.
Where did you pick up manifold pressure?
Old 08-24-2016, 09:56 AM
dos531's Avatar
Originally Posted by flightlead404 View Post
Thanks Dos531.
I believe I got it off the throttle body, ill have to double check.
Ducati 748R
Old 08-24-2016, 10:16 AM
The line that originally went to the thermo valve in the breather cover?
Old 08-24-2016, 10:31 AM
dos531's Avatar
Not sure, that thermovalve hasnt been hooked up in a long time on my car.
Ducati 748R
Old 08-24-2016, 01:18 PM
