964 Turbo PC in 930 engine
Does anybody know if the P&C of a 964 Turbo fit in a 930 3,3 engine from 1988? I was thinking of the benefit of the head gasket / CE ring and the cooling fins. Or are for example the heads different?
Many thanks,
Malte
Old 11-15-2016, 10:12 AM
TurboKraft's Avatar
Malte -- the 1991-92 3.3L Turbo do fit. Yes, you must machine the heads to C2T specs.
The cooling fins are an improvement, makes the barrel stronger as well.
The head gasket is not really an improvement in our experience.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 11-15-2016, 10:36 AM
Thank you Chris, what modifications need to be done to the heads?
Old 11-15-2016, 10:59 AM
TurboKraft's Avatar
Machine the sealing surface of the heads to allow for the stainless flat shim (not really a gasket).
Most 911-specialist machine shops will have this spec.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 11-15-2016, 11:17 AM
Thank you very much!
Old 11-15-2016, 01:50 PM
