-   -   How to you get that durn S shaped turbo inlet pipe out? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/937437-how-you-get-durn-s-shaped-turbo-inlet-pipe-out.html)
flightlead404 11-29-2016 05:11 PM
Like the title says, I'm trying to figure out how to get out that twisty turny aluminium pipe that goes down through the sheet metal to the inlet side of the turnbo.
Any hints?
icemann427 11-29-2016 06:31 PM
Well, loosen the rubber connector that attaches the pipe to the turbo and slide the rubber connector as far up the pipe until its outer edge is even with the end of the pipe. Loosen both sides of the upper rubber connector and slide it away from the pipe you want to remove. Turn the bottom of the pipe 90 degrees clockwise where the open end is toward the back of the car. Push the bottom of the pipe forward while you wiggle and pull down on the pipe and it should come out.
Rawknees'Turbo 11-29-2016 07:33 PM
Originally Posted by icemann427 (Post 9377382)
Push the bottom of the pipe forward while you wiggle and pull down on the pipe and it should come (out).
:eek:
IcyHotness, you are such a perv (and a pipe expert, too) !!!
:eek:
icemann427 11-29-2016 07:47 PM
And here I elected not to disparage your sweet name by purposely leaving you (Rawknee) out of my post... :) lol
Rawknees'Turbo 11-29-2016 07:49 PM
That'll learn ya'!!!
:D
icemann427 11-29-2016 07:51 PM
lol
T77911S 11-30-2016 05:18 AM
I have to drop the tail of my motor, but mine is not stock.
not sure if I had to remove or undue the rear sheet metal.
flightlead404 11-30-2016 04:29 PM
I had to loosen the sheet metal and bring it out the top. There's no way it was coming out the bottom.....
"coming out the bottom"? OMG what have I done!!! Oh, The humanity!
Rawknees'Turbo 11-30-2016 04:57 PM
Top, bottom, sideways, upside down, or backwards is all good to IcyHotness!!! :eek:
icemann427 11-30-2016 07:34 PM
Don't forget my damn whip!!:eek:
JFairman 11-30-2016 08:34 PM
i made the hole bigger
Jeff NJ 11-30-2016 08:38 PM
Ronnie just passed out.
Rawknees'Turbo 11-30-2016 08:39 PM
:eek: :eek: :eek:
Rawknees'Turbo 11-30-2016 08:42 PM
Never, Bro!!!
https://s-media-cache-ak0.pinimg.com...2ce99afe07.jpg
