How to you get that durn S shaped turbo inlet pipe out?
Like the title says, I'm trying to figure out how to get out that twisty turny aluminium pipe that goes down through the sheet metal to the inlet side of the turnbo.
Any hints?
Old 11-29-2016, 05:11 PM
Well, loosen the rubber connector that attaches the pipe to the turbo and slide the rubber connector as far up the pipe until its outer edge is even with the end of the pipe. Loosen both sides of the upper rubber connector and slide it away from the pipe you want to remove. Turn the bottom of the pipe 90 degrees clockwise where the open end is toward the back of the car. Push the bottom of the pipe forward while you wiggle and pull down on the pipe and it should come out.
Old 11-29-2016, 06:31 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Originally Posted by icemann427 View Post
Push the bottom of the pipe forward while you wiggle and pull down on the pipe and it should come (out).
IcyHotness, you are such a perv (and a pipe expert, too) !!!
Old 11-29-2016, 07:33 PM
And here I elected not to disparage your sweet name by purposely leaving you (Rawknee) out of my post... lol
Old 11-29-2016, 07:47 PM
That'll learn ya'!!!
Old 11-29-2016, 07:49 PM
lol
Old 11-29-2016, 07:51 PM
T77911S's Avatar
I have to drop the tail of my motor, but mine is not stock.
not sure if I had to remove or undue the rear sheet metal.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-30-2016, 05:18 AM
I had to loosen the sheet metal and bring it out the top. There's no way it was coming out the bottom.....
"coming out the bottom"? OMG what have I done!!! Oh, The humanity!
Old 11-30-2016, 04:29 PM
Top, bottom, sideways, upside down, or backwards is all good to IcyHotness!!!
Old 11-30-2016, 04:57 PM
Don't forget my damn whip!!
Old 11-30-2016, 07:34 PM
i made the hole bigger
Old 11-30-2016, 08:34 PM
Jeff NJ's Avatar
Ronnie just passed out.
1988 930 Venetian Blue
Old 11-30-2016, 08:38 PM
Old 11-30-2016, 08:39 PM
Never, Bro!!!
Old 11-30-2016, 08:42 PM
