First Start 3K rpm.
Hey Guys.
I had my 77 930 engine out and tuned up and clean it up very nice
I installed the engine this weekend and started right up ...
The ilde is very high ...3000 rpm,. I cannnot bring it down,, 4adjusting the idle screw does nothing..
I checked and re checked all hoses and clamps
tested the Aux Air it closed fully with 12V and opened fully in freezer.
I was thinking it Must be the Idle decel valve? the round gold thingy ?
Will that shoot the RPM to 3K ?
thanks for any advise
Old 07-05-2019, 12:42 PM
Crotchety Old Bastard
RarlyL8's Avatar
Check the throttle rod at the transmission, could have been bent during engine drop or install.
Old 07-05-2019, 05:59 PM
7.0:1 > 11.3:1 > 7.0:1
You certain that the line to the brake booster is connected onto your intake manifold?
Old 07-05-2019, 08:41 PM
16Volt's Avatar
I had a similar issue - the throttle rod was binding thus keeping the throttle open.
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 07-05-2019, 09:24 PM
Non User
infraredcalvin's Avatar
Check pedal bushings, just had that issue on mine.
Also if you have a hand throttle, check the lever and the bushing
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 07-05-2019, 10:10 PM
Yes I checked the throttle rods..
I even disconnected it on the trans so it would be free. no diffence.. 3K rpm
Would a stuck recirculation valve make a high RPM? i did install the two new gaskets in there
Old 07-06-2019, 03:50 AM
RarlyL8's Avatar
If it's not the throttle then you have an open air leak somewhere. Identify which throttle bypass devices you have and render them inoperable one at a time by pinching or plugging the vacuum line.
Old 07-06-2019, 05:26 AM
Ended Up being a crack in the U tube caused by the hose clamp couldnt see is under the cloth but once i removed it , it was totally noticeable..
What a pain in the ass to replace that hose it with the engine in .
ALL fixed ,, nice idle now..good revs and back down to 900rpm now.
thx
Old 07-06-2019, 10:29 AM
