Stranger on the Internet
patkeefe's Avatar
Fuel Pressure Regulator
I am switching the CIS in the SC over to EFI (SDI). I have picked up Accel 44# injectors (I only run ~6 PSI boost). I am imagining I need to get a fuel pressure regulator to knock the pressure down to 45 PSI (IIRC). Do you EFI guys simply get a return type regulator, and ditch the accumulator? Do 930's even come with accumulators from the factory? (I suspect yes). I am trying to picture this setup in the engine compartment. Also, I imagine some regulators are better than others?
TIA. Any insight is helpful!
Pat
Patrick E. Keefe
78 SC
Old 12-03-2016, 08:15 PM
scottrx7tt's Avatar
You will need a rising rate fuel pressure regulator for boosted applications. I am running a cheap aeromotive, and it works great. You will need to ditch the accumulator.
https://www.aeromotiveinc.com/product/efi-bypass-regulator/
Old 12-03-2016, 08:38 PM
patkeefe's Avatar
Thanks scottrx7tt,
Does 1:1 rising rate mean for every PSI boost pressure, it delivers 1 extra PSI of fuel pressure? I see it supports 1000 HP. In my dreams!
Patrick E. Keefe
78 SC
Old 12-03-2016, 08:50 PM
scottrx7tt's Avatar
Originally Posted by patkeefe View Post
Thanks scottrx7tt,
Yessir!
Old 12-03-2016, 09:03 PM
patkeefe's Avatar
Thanks again!
Patrick E. Keefe
78 SC
Old 12-04-2016, 07:10 AM
kuehl's Avatar
Pat,
I have a Corky Bell rising rate FPR. Used it very little.
Modified the adjustment pressure screws to knurled knobs so you can make quick adjustments
without taking out tools. Let me know if you are interested.
Griff
(nj)
Model 2035
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 12-04-2016, 11:42 AM
