Tinkering Pays!!
mooney265's Avatar
Question WEVO Shifter Help
The WEVO guys are out of the country for a few weeks, so I thought I'd put it to you guys. I had to remove my Shifter & E-Brake to access the throttle bushings and replace. After doing so, I put back together [thought I put shifter back in same spot as I marked with Tape and Pen Markings.
The car shifts into all gears [including reverse]. However, there is a tremendous amount of slop in the shifter, now. Also, all of my bushings and the joint are only about 2-yrs old, as I changed them with the shifter...
I've attached a video https://youtu.be/487Ke29yjro
of my predicament. Can anyone tell where my problem is right off the bat [with the video]?
Thanks, Shannon
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 05-23-2017, 09:08 AM
Jeff NJ's Avatar
Did you check all the bushings between the shifter and the wevo to make sure they didn't become dislodged? That's what it looks like to me.
1988 930 Venetian Blue
Old 05-23-2017, 09:24 AM
Tinkering Pays!!
mooney265's Avatar
These are the only bushings/connections that I know of...
Old 05-23-2017, 09:30 AM
Jeff NJ's Avatar
Yeah, I was thinking if #10 popped out, it would cause slop like that.
Old 05-23-2017, 09:37 AM
Tinkering Pays!!
mooney265's Avatar
Maybe it did "pop out" will need to verify - - thanks!
Old 05-23-2017, 11:12 AM
If you have access to a borescope or camera on a flexible arm, you can view that bushing via the shifter adjustment coupler plate on the trans tunnel without removing all sorts of console parts
Ken
1986 930 2016 R1200RS
Old 05-23-2017, 01:34 PM
Tinkering Pays!!
mooney265's Avatar
Looks like consensus is: the shift rod bushing may have come dislodged in the re-install... Sounds plausible. Unfortunately, leaving town tomorrow for the beach.
Will check the bushing when i return and report back. Thanks a bunch!
Old 05-23-2017, 03:17 PM
Tinkering Pays!!
mooney265's Avatar
Turns out the culprit was #9. I must not have 'snapped' the shifter into this part before assembling.
Also noticed that my shifter assembly "spacer" may have been creating too much space between these two parts, so I removed the spacer. Had to get a shorter bolt for the rear of the shifter as the original one was binding on the shift rod [due to decreased space from spacer removal].
All-in-all, the shifter now works like a charm! Took 45-minutes
Old 06-09-2017, 06:07 AM
Yeah it takes a good amount of force to get the end of the shifter into #9, ball kind pops into the socket. But once it's in it's usually in solidly.
'72 911 ST Tribute (built by Scott Longballa) - Signal Yellow
'74 911 Carrera Targa (2.7 MFI - RoW) - Silver / Polaroid Stripes
'77 930 - Minerva Blue
'97 993 Turbo S - Ocean Blue Metallic
'13 981 Boxster (BGB 3.8L 991S conversion) - Racing Yellow
Old 06-09-2017, 08:30 AM
Jeff NJ's Avatar
Nice! Easy peasy and back on the road!
Old 06-09-2017, 08:34 AM
