ivanuf's Avatar
Wastage Spring Identification
Need help to identify this spring.
From other spring id postings, I could not find one that matches this one
This one as you can see on the picture has 6 loops and is slightly taller than others
that are on past postings.
Here are the measurements:
Width = 2.706"
Wire thickness = 0.192"
Uncompressed spring length/height = 7.6250"
From other members and past postings I understand that stock pressure for 76-77 930 wastage spring was 0.6 bar, is this correct?
Is this the factory spring or is it an upgraded spring?
Ivan
79 SC Back to Basics!
2006 997 C2s Cabrio - Sold
1999 996 C2 - Sold
Old 06-07-2017, 08:42 AM
ivanuf's Avatar
A member wrote to me the following message:
That spring looks to be a 0.8 bar spring from a 3.3 although I typically see 0.196" wire diameter on the oem 0.8 bar 3.3 springs. What you car do you have?
I have a 77 turbo with 3.3 bottom end (pistons and heads) so I guess it has a 0.8 bar spring from a 3.3 turbo?
1999 996 C2 - Sold
Old 06-08-2017, 07:03 AM
3 restos WIP = psycho
kenikh's Avatar
I've tried all of these measurements and they are so inconsistent as to be useless.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-08-2017, 04:39 PM
For what it is worth I Just measured a .8 bar spring as follow: diameter .210, width 2.726, and 6.375 long.
Old 06-10-2017, 07:26 AM
