Euro Ride Height?
Looking for euro ride height info,measurements from front and rear fenders to the ground. Thanks in advance.
Tim 87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost.... Gone: 85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims. |
Euro height front...about 2 inches too high.
Euro height rear about 1-1/2 inches too high. Helpful I know...... :} Mark |
I agree, "EURO" ride hight is too high.. off the ground. I set it where it looks good to me and everyone else that's seen it agrees.
Once you've decided where you like it do a front toe adjustment and check the rear toe. The rear toe doesn't change much with small changes in ride hight and it's a lot of work to adjust it, and then drive it to settle the new adjustment, and then check it again with strings squared off around the car at center hub hight. |
Jim, does a ride height adjustment only change the toe? I want to tweak my ride height, but don't want to pay for another alignment. If its just toe, that I can do. Camber, caster, etc., not so much.
1988 930 Venetian Blue |
Yes, it only changes toe in the front end.
Caster and Camber remain the same. You have to move the top of the strut which is mounted in the camber plate around to change those settings. |
Banned
keep in mind Tim ERH refers to stock wheels
that data is bunk on your 18" hooptie's Set it where you like it and forget it agreed tho - yours does currently run a bit high and will look TITS properly set now w/ that biitchen front valance 8-) |
Yes need to drop it with my hooptie's and new valence on. Need to get some street cred!
You really need to set height where you want then do full alignment AND a corner balance
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp |
Banned
oh yeah cb/align fersure
also factor in a bumpsteer kit if you've not already installed |
Eng-o-neer
"Euro" height applies to a few early cars and is not measured using the fenders:
1987 carrera pros & cons of lowering to European Height from stock? You can lower it to where it looks the way you want it, but there can be handling compromises that will go with it. |
Doesn't it also affect the weight at each wheel?
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S |
If you visually watch your socket wrench and turn both front ride hight adjustment bolts the exact same amount I don't see why it would affect the weight difference on the front wheels or the rear wheels.
If I'm wrong correct me with an explanation. |
Lowering a cars ride height has more affect on alignment than some of you guys are eluding to.
As the suspension moves up-n-down, the wheel does not move in a linear fashion, the suspension geometry causes it to move in a slight arch. The more you lower the car the more observed negative camber is seen (top of the tire moves inward toward the center of the car). Depending on how much you lower the car, will dictate how much camber change will be observed. Even caster is affected when lowering, just not as much as camber, and toe changes goes without saying. My car is lower than most on this forum, and it took a lot to correct the suspension geometry on my car after slamming it, don't be fooled, dropping ride height affects EVERYTHING! Mark Last edited by full quack; 04-11-2017 at 01:10 PM.. |
Nope, Not saying you are right or wrong, just asked a question as I was curious thats all....
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S Last edited by timc; 04-11-2017 at 02:36 PM.. |
Sent from my SM-P607T using Tapatalk |
The basic list is as follows...
1.) Raised front spindles 40mm. 2.) Custom length Von shocks and inserts with valveing for my specific torsion bars. 3.) 30mm/23mm torsion bars. 4.) Rebel Racing front control arm bushing replacement blocks. 5.) Rebel Racing rear pivot replacement bushings and torsion bar tube mounts. 6.) Tarrett 22mm adjustable sway bars front & rear. 7.) Wevo weld on rear sway bar mounts. 8.) Fikse custom 3 piece wheels 17 x 8.5 fronts, 18 x 11 rear. 9.) B.F. Goodrich comp-2 tires 255-40 fronts, 295-35 rears. 10.) Elephant Racing welded on bump steer correction system kit. 11.) Strut tower brace. 12.) Hawk HSP front pads, Pagid RSR Black rear pads, all new rotors. 13.) Full alignment & corner balance, with the car setup with the proper 1.5 degree front to rear rake angle. That pretty much sums it up. Car sits with 2" clearance under the front spoiler....:} Mark Last edited by full quack; 04-13-2017 at 07:21 AM.. |
