Dial in your compression?
I was just curious if anyone has hurd about this technology? I am not sure about how it works and was wondering if any of you could shed some light on the subject.I thought it to be interesting and would be awsome on turboed motors.
Sent from my SM-N910T using Tapatalk |
Or was i just dreaming
SAAB had a variable compressor boost engine in the 2000-2001 timeframe. GM bought Saab, killed the program for cost reasons, killed Saab, sold back Saab, then GM killed themselves. The technology was different but accomplished the same.
In the 70s I worked on a variable compression diesel destined for Abhrams battle tank. Pistons moved up and down by oil pressure, worked great. Pentagon Army types wanted a turbine like everyone else, so the tank got a turbine instead. Frankly this concept looks like a bunch of claptrap that will not be compatible with high revs. Also 1.5 seconds is very slow response when you want boost/power now. Think about that. What is significant to me is their acceptance that 8:1 is desirable in this modern engine. Makes a good case for 7:1 being more reasonable for our 50 year old motors. |
I might be wrong but believe Porsche owns the patent and is putting this in there new gt2rs its a interesting concept and thought what if any benefits it might have.Thanks copbait i also look forward to your input..
Nissan presented this at last months Society of Automotive Engineers convention. The explanation is a little detailed, but think of it as a rotating rocket arm. It is no longer the slider crank mechanism we know and love. Here are my notes:
The rod big end now makes an elliptical motion, with the long axis along the cylinder axis. As a result, the conrod remains more vertical. This means it pushes less on the cylinder walls. Piston friction is claimed to be reduced by 44%. Compression ratio can be varied from 8 to 14. (The Continental VCR referred to by Copbait had less than half that range, with no friction reduction.) The full range switch time was not mentioned. There are many other VCR schemes, but this is a Nissan patent. Here is a pic. http://forums.pelicanparts.com/uploa...1494035975.jpg |
Another interesting technology was the BorgWarner eBooster electric compressor assist:
http://forums.pelicanparts.com/uploa...1494037699.jpg |
What controls the system?Can it be controled manually?Can you add less compression and more boost?Sounds exciting
I heard there was herd of 930 enthusiasts on here.
They use one electric motor to move all the pivots up or down together. The said they have run over one hundred engines for three million miles so far, and that there was a separate ECU just for the variable compression. No cable attached to levers between your seat to turn your CR to 11 though;)
6000 tr/mn maximum with this system.
http://www.liveanimalslist.com/mamma...rd-picture.jpg |
Here is the Saab system. It lifts one side of the whole head to lower compression. It was super-expensive, and also did not have a very big range of CR's.http://forums.pelicanparts.com/uploa...1494100135.jpg Here is the Continental Engine vcr from the '60's. It used oil that came up the connecting rod shank to jack up the piston crown. This was a diesel application. http://forums.pelicanparts.com/uploa...1494100463.jpg I think gas turbines won the tank engine contract because they don't need much of a radiator. Diesel tanks can be knocked out by punching a hole in the radiator. |
Raising compression raises cylinder head temperature quite a bit. With water cooling you have a thermostat and the headroom to control that.
With air cooling there is no extra cooling headroom.. all you can do is put a different pulley on the fan to speed it up a little and hope for the best and/or install extra oil coolers to cool the oil more. |
| All times are GMT -8. The time now is 11:38 AM. |
