Twin turbo blow of valve
Hi all nearly finishing putting this engine back together and my question is.. do you need to run a blow of valve on the intake pipes from each turbo or can I use just one on the plenum. I am using individual throttle bodies with a U shaped plenum around the flat fan setup...
Old 05-23-2017, 02:59 AM
E-85 sippin drunk
turbobrat930's Avatar
A blow off valve is there to let the build up of boost pressure out, when the throttle is closed. The purpose is to prevent the back up of that pressure, which will cause damage to the compressor wheel. As such, it does not matter where you put it, as long as it functions. I have been told to attempt to (in a perfect world) locate it as close to the compressor outlet as possible. But, put it where you have the space.
If you have completely separate I/C's, plenums, etc... then yes, you will need two of them. If both of the compressors discharge into a common plenum, then one will do.
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 05-23-2017, 05:45 AM
Thanks for the input so I will run 2 blow of valves one on each intercooler pipe just before the plenum.... Any recommendations on types or brands...
Old 05-23-2017, 10:55 PM
Ken911's Avatar
mine are turbo smart bov's and also wastegates.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 05-24-2017, 06:08 AM
Chain fence eating turbo
Best to put the BOV's right after the compressor outlet to aid boost recovery.
If you dump right before ITB's, all the pressure has to be refilled from compressor to ITB's taking much longer recovery.
Old 05-24-2017, 06:33 AM
E-85 sippin drunk
I have both TiAL wastegates, and their BOV. They do make a good quality product, but their customer service SUCKS!!!! Based on that fact alone, I will NEVER own one of their products again.
I have heard good things about Turbosmart.
Old 05-24-2017, 08:02 AM
Good to know.
I have an HKS that I've had for 21 years now that's been on 2 different cars that works fine.
Old 05-24-2017, 10:19 AM
16Volt's Avatar
FWIW I use TiAL wastegates and Forge BOVs on my turbo cars.
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 05-24-2017, 11:16 AM
TurboKraft's Avatar
I've concluded this is all theoretical, and in the real world it has no discernable effect..
We put twin BOVs on the plenum housings of HAMS' 930, and there is zero waiting for the system to be recharged.
Those compressors are displacing an extraordinary amount of air, and that doesn't stop just because a BOV opens. It refills nearly instantaneously.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 05-24-2017, 12:00 PM
Ken911's Avatar
mine are going on the plenums. Mostly because they will fit there the best.
2019 Silverado 6.2L
Old 05-25-2017, 06:34 AM
Even on singles? I thought about after posting, maybe twins don't have this problem unless they're very large for the displacement of engine they're on.
Old 05-25-2017, 06:54 AM
The theory was akin to disconnecting an air hose from an air compressor. If you disconnect at the coupling, it takes time to bleed the pressure. If you reconnect quickly, you won't loss the entire pressure in the line, thus taking less air to get the pressure back up to say, 125PSI.
Apples to oranges I guess, but similar behaviors.
Old 05-25-2017, 06:57 AM
Ken911's Avatar
I just had a thought about twin wastegates. I was planning on running them both out the back of the car next to the outlet of a Zork tube. How evil would the car sound on boost if I cut notches similar to those in a steam whistle in them.
2019 Silverado 6.2L
Old 05-25-2017, 07:07 AM
E-85 sippin drunk
Are we talking about BOV's here or WG's?
As far as WG's are concerned, I run two of them. Since I had Brian make me the headers, it was an easy choice to do the dual Wg's. It definitely sounds awesome when they open up ))) Here is a video of the underside of my engine, showing the twin WG's...
idle from under car.
Old 05-25-2017, 08:29 AM
Ken911's Avatar
well the thread is for bov's but just thinking how mean you could make a waste gate sound.
2019 Silverado 6.2L
Old 05-25-2017, 08:37 AM
E-85 sippin drunk
Trust me Ken, with the engine you are building... you will not need any help making that thing sound wicked!!!! Just put that right foot to the floor
Old 05-25-2017, 08:53 AM
Ken911's Avatar
I sure hope so. The thought of getting it running and setting up the maps is kida terrifying, but know eventually it will all be ok. The first couple times there were always things I wanted to do but couldnt afford. This time it's going to be exactly what i want which is why it's taking forever.
2019 Silverado 6.2L
Old 05-26-2017, 05:52 AM
Ingenieur
It is theoretical, but the theory is correct. Your toilet wouldn't flush if it weren't! I suppose if you are measuring using a "butt Timex" it is instantaneous, but with a little instrumentation you can measure the difference. Here is a shot of the Honda HR28TT. The tan colored circular cover is the BOV. It is as close to the compressor diffuser as you can get, the "theoretical" best position. Packages nice too. Standard stuff on BW turbos nowadays.
Old 05-27-2017, 07:25 AM
Yes sir, that's where I learned the theory - from BW.
My boost recovery is insane for the largest, mid-frame turbo from BW.
When you see the little red light come on at the bottom left of the video, that indicates 1 bar:
https://youtu.be/yjzWI9GGkTQ
Old 05-27-2017, 10:00 AM
Thats freekin crazy.
Sent from my SM-N910T using Tapatalk
Old 05-27-2017, 01:37 PM
