lambda system freeking out in a 930
hi fellows Pelicans.
lambda system is freaking out in my 86 930. it is a US version - 930/68, with lambda circuit controlling mixture/emission. car runs great without lambda sensor connected. once it is hooked up, however, AFR goes down to ~10 or even below. once sensor is disconnected, it goes back to whatever is set using mixture screw. below two videos showing how it behaves. https://youtu.be/dVhl5wPgZIg https://youtu.be/yJJd4x7ESO8 lambda sensor has already been replaced with new unit. anyone any ideas? thanks! Krzysztof |
do you mean the O2 sensor was replaced?
check speed relay, perhaps bad solder joint. one side it for the fuel pump the other for the O2 sensor throttle position switch |
hi folks,
thought i'd come back to this thread to report on the solution. appeared that it was a bad ground. ended up adding addn'l grounding wire to the o2 sensor brain unit and all is back to the order now. thanks for suggestions! Krzysztof |
| All times are GMT -8. The time now is 04:49 AM. |
