lambda system freeking out in a 930
hi fellows Pelicans.
lambda system is freaking out in my 86 930. it is a US version - 930/68, with lambda circuit controlling mixture/emission. car runs great without lambda sensor connected. once it is hooked up, however, AFR goes down to ~10 or even below. once sensor is disconnected, it goes back to whatever is set using mixture screw. below two videos showing how it behaves. https://youtu.be/dVhl5wPgZIg https://youtu.be/yJJd4x7ESO8 lambda sensor has already been replaced with new unit. anyone any ideas? thanks! Krzysztof
VW 1200 Sparkafer 1973 VW T2b Westfalia 1979 Porsche 930 Turbo Carrera US, 1976 ================ 911S 1976, 930 1986 - both gone |
do you mean the O2 sensor was replaced?
check speed relay, perhaps bad solder joint. one side it for the fuel pump the other for the O2 sensor throttle position switch
hi folks,
thought i'd come back to this thread to report on the solution. appeared that it was a bad ground. ended up adding addn'l grounding wire to the o2 sensor brain unit and all is back to the order now. thanks for suggestions! Krzysztof
