-   -   turbo support bracket delete? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/963397-turbo-support-bracket-delete.html)
bpu699 07-18-2017 04:29 PM
Timely thread!
My car is also missing this bracket...
Oddly, it has a heavy custom made exhaust, as my 930 has a 965 rear bumper... The exhaust is heavy steel, and that has a bracket that mounts to the motor...
Serves the same purpose I suppose...
The muffler is hard mounted, and supports the turbo...
Garen 07-19-2017 07:44 AM
I made one too:
http://forums.pelicanparts.com/uploa...1500475469.JPG
boosted79 07-19-2017 09:06 AM
Trick. You probably only need the top one with that setup.
356911930 07-19-2017 09:13 AM
With only one of those turnbuckles the turbo will swing fore and aft and rattle around I would think.
Rahl
1979-930 07-19-2017 09:17 AM
IDK. I looks cool, but hiem joints allow movement and the point of the support is to stop movement. It's probably fine.
How many miles with that setup?
boosted79 07-19-2017 09:57 AM
All you really have to do is take the weight off the headers.
timc 07-19-2017 11:27 AM
Originally Posted by JacobS911 (Post 9664881)
I picked up one from turbokraft. It's for a k27 however. Maybe they make them for stock turbos? Or just get a k27 and that bracket :p
http://forums.pelicanparts.com/uploa...1500263183.jpg
Wouldn't this fit any turbo, as the location of the turbo mounting flange off of the header does not change, and most of the time remains consistent???
timc 07-19-2017 11:35 AM
Originally Posted by WERK I (Post 9665474)
Got tired of the different sized turbine housings and purchased TurboKraft's turbo support bracket. According to Chris, this bracket will support any T3 turbo that mounts the turbo in the same factory location (B&B, Fabspeed, factory, etc.). No more double turbine exhaust gaskets, no more worrying about if it's 3LDZ,7006,7200, Garrett, BW. Thanks Chris!
http://forums.pelicanparts.com/uploa...1500317164.jpg
I like that, simple and works. I don't see it on his site, is it a special order?
TurboKraft 07-19-2017 11:52 AM
No, not special order, just not up on the site yet. Maybe this week. Too many car builds in process...
We have made them for the 1976-83, 1984-89, 1991-92, and 1994 models.
As long as the turbo is still K27/T3 flanged, it works.
Garen 07-19-2017 01:28 PM
No miles yet. The car is an ongoing project that is taking WAY too long. I had two turnbuckles left over when I freshened my SRP anti roll bars, and this looked like a good experiment. It will keep the weight of the turbo/header supported, and allow for a bit of thermal movement (although triangulated like that, there isn't much opportunity for movement I bet). At least that's my story... :cool: plus the yellow matches nicely with the WEVO engine mounts. Oh yeah. Color-coordinated. Yup!:D
