Break in oil recommendations
Title says it all. What oil for break in.
thanks.
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
Oil for the first 500 miles. I'll switch to Mobil 1 after that.
I use Valvoline VR1 20W-50 with a bottle of Crane Cams break-in additive. Never had a failure.
1986 Ruf 930 2015 991 GTS-MT 2006 993 S-MT (Gone) 1969 911 T (Gone) |
Delo 15-40. Save the non-detergent for your Briggs and Stratton. Here we go..
So, Bradd Penn 15 min break in, Valvoline or Delo first 500 miles?
3 restos WIP = psycho
Gibbs BR
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Ditto. Joe Gibbs "Driven BR" Break-In Oil, 15W-50 Conventional
No Brad Penn in Turbos, IMO.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Thanks. 15-50w conventional for how many miles before Mobil 1.
What we usually recommend for high performance street engines with new P&Cs:
a) first 500miles -- Driven BR Break-In 15W-50 conventional Drain, inspect drain plug and filter element (cut open with cutter or tin snips). b) next 500-1000 miles -- Driven HR Hot-Rod 15W-50 conventional Drain, inspect drain plug and filter element (cut open with cutter or tin snips). c) forever -- synthetic of choice, ex: Driven DT50 Street Performance 15W-50 synthetic Each time we drain the oil, we scrutinize the drain plug and filter element (cut open with cutter or tin snips).
What have you seen with brad penn? I used it. Nice oil pressure but now a bad cam lobe. Is it the oil? No idea. What's your experience?
The second post is by Supertec who's not too happy with Brad Penn.
Break in oil- first 20 minutes- Brad Penn or standard non detergent It would be nice to have a sticky on the turbo forum for oil, break in etc, as it seems to differ from the n/a motors.
Bpu l had the same problem years ago with Brad Pitt/ Sean penn oil. Ruined a set of cam lobes. Never went back. Glad to see Chris feels the same
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp |
Brad Penn also cokes up turbos
