			My thought also. All happened in slow mo. Aquaplaned then slowly half rotated as I tried to get it back. Almost had it - then the concrete wall jumped out and attacked the front. I quickly put the engine in the back and saved that bit. Not much up the front anyway.  A 964 right in front had same, but managed to save it.
				The crash crew arrived , asking if I was OK My concern was I couldn't get reverse to get the car off the wall. They kept asking if I was OK, I kept complaining I could not find reverse. The car had been shortened enough the clutch cable would not work. Needed a new adjustment. Alan
	83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)  |
			Get rid of all that BS and wire in an inertia switch. Wire a sw into the pump coil circuit so you can turn the pumps off with the ign sw on if you want to since the pumps will be on as long as the ign is on. Inertia sw is out of a Taurus.
 If you have the airflow plate sensor in the circuit the fuel pumps ground through that so it should shut off for you.  |
			I should have added that the red jumper from 85 to 86 is not necessary for the inertia sw install. I jumpered it to send power to the air meter contact connector which I then used to supply 12v to my Pierburg valve. The inertia sw mod eliminates two of the most common problems on these cars, the  air meter "overboost" relay and the air meter contact.
			Also, the air meter "overboost" relay, red or yellow, is a misnomer, it has nothing to do with overboost protection. The boost limit sw located on the intake provides that by opening the ground side of the pump relay coil circuit. The only thing that triggers the air meter "overboost" relay is the air meter contact. This is on a '79, pretty sure the later years are the same except they added a time delay circuit in the "overboost" relay so they can charge $100+ for a stupid $5 relay. Get a $5 Taurus inertia sw at a pick and pull. Last edited by boosted79; 09-30-2017 at 05:29 AM..  |
			What do those fuses ( below the relay 's )control .?
			My middle fuse is missing the bottom one was burnt out / broken. Replaced the bottom one and dropped the one for the middle.😡 Was wiggling everywhere and now car won't start today .
	Scott D Anderson 88 930 Turbo 74 914 LE Bumble Bee  |
			 Mighty Meatlocker Turbo
 I was thinking of you when I made this thread and was hoping you'd chime in (forum leg humping and butt snorkling) - I really like your idea and may copy it. Really weird that the yellow relay has become known as the "overboost relay" - I'm pretty sure that it is even labeled "boost, or air pressure relay" in the PET - strange stuff.  |
 The middle fuse on an 87 Turbo is not used (it is for the "engine compartment fan" used on non-turbo 911s) The bottom one says "passenger compartment fan", but I don't know which one they are talking about. The top fuse is for the rear window defogger element.  |
			The top fuse for the rear defroster grid is good to supply power to an MSD after disconnecting the heater grid wire.
