Garage Queen
Shifter knob separation
Folks,
My 87 930 has this 3mm gap on the front and back of the shifter knob. Is this normal?
Stephanie '21 Model S Plaid, '21 Model 3 Performance '13 Focus ST, Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3, |
Negative Ghostrider. It should be smooth.
Ingenieur
Mine is exactly the same, and I know how it got that way. Like mine, your shift knob was once leather covered, with only the shift pattern showing. The leather wore off and became loose, so someone cut it away just like I did to mine. After awhile I got sick of it and replaced it with a different knob.
Garage Queen
Thanks guys. That make complete sense.
Boost Is Better
Back from the graveyard as not to spam the forum too much.
Can you folks tell me how the factory 930 shift knob is attached to the shifter? I've got a copolymer project in the works. Is it threaded? If so, would anyone happen to know the thread pitch? Many thanks in advance as usual.
Boost Is Better |
Champagne on Beer Budget
The shift knob is threaded..unsure of the pitch. Mine looks just like the photo above...no more leather.
Einar www.einarsgarage.com Instagram @einars_garage https://www.facebook.com/pages/Einars-Garage/375533809160797 |
Boost Is Better
Thanks so much for the reply and confirmation, that's a step in the right direction. I'm assuming it's of course metric. I would be very grateful if you had some way of determining the specific pitch. Thank you again for your feed back.
Boost Is Better |
If it's like my 87, it uses a crush collar to keep it installed. I used an open end wrench just wide enough to go over the shift lever and tap the bottom of the wrench with a hammer to lift it up.
If it was screwed on, it would have a jamb nut or allen screw to keep it from spinning IIRC. |
sudo apt-get purge 930
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Boost Is Better
Sorry to nag about it, it's just that the car is in CZ which is six hours ahead of us so it can be difficult to catch the guys in the shop and have them take the measurements directly.
Boost Is Better |
Hold on! My '87 you have to carefully pry off the the top cap and then you unscrew a bolt and the shifter comes off.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD |
^^^ I could wrong then. I know I did it to either my 911SC or my 930.
Boost Is Better
'86 and older ![]() '87 and newer
Boost Is Better |
Boost Is Better
We've got some aftermarket junk knob in our car, so if any endeavoring soul would be kind enough to measure the depth and diameter of the opening of a factory '86 and older shift knob, I would be much obliged.
Boost Is Better |
Questions on this thread thread for my 79 930.
I have the crush sleeve. Question do I need to totally remove the shifter to avoid damaging the shifter mechanism to separate shifter knob from shifter? Taking a wrench and a hammer and beating on it sounds like it would damage the shifter mechanism if it was left assembled. I guess I'm asking if I need to totally disassemble the shifter mechanism to safely remove the shifter knob as you would have to use a hammer and wrench to remove it. Sent from my iPhone using Tapatalk
http://9309700485earlyturbo.wordpress.com |
